Old 05-16-2022, 10:50 AM #1
T4RunnerSteve's Avatar
T4RunnerSteve T4RunnerSteve is offline
Real Name: Steve
T4RunnerSteve is on a distinguished road
Real Name: Steve
T4R Rolling Coal?
Hi all --
I have a TRD supercharged '02 T4R w/ the AEM FIC-6 and Supra injectors. The truck has worked well with this setup for the past 4-5 years but recently after driving for ~30 mins it suddenly starts running ridiculously rich -- pegged at 10 AFR on the wideband with black puffs coming out of the tailpipe. This often happens on the highway and around 50 MPH the truck starts bucking violently until I let off the gas. When throttle is added it pops back down to 10 AFR but when coasting it is around 11-12 AFR. Once it gets to this point, it will stall down at lower speeds (like at the end of the the offramp), sitting at traffic lights, for example, and becomes hard to start. After letting it sit for a bit it will restart and run normal again until it goes through all of the above, once again.
Any ideas on where to start here? I cleaned the MAF sensor but am suspicious of it, the oxygen sensor and perhaps the AEM FIC-6 itself. Code P1130 has been triggered and this phenomena is happening earlier and more frequently by the day; feels sensor related. Your advice is appreciated!
Thank you!
-Steve
2000 Toyota 4Runner Highlander Edition - Manual, 3.5” Lift, 17” TRD Pro rims, 32s - son's future 1st vehicle
2002 Toyota 4Runner Sport Edition - TRD SC, AEM FIC-6, 3.5” Lift, 17” Sequoia rims, 33s - toy
2013 Lexus LX570 - 22” rims - wife’s truck
T4RunnerSteve is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 12:19 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I would start with checking all the spark plugs, spark plug wiring, and verify you are getting spark
Old 05-16-2022, 12:44 PM #3
HiLife HiLife is offline
Check the temp sensor at the front of the block. Make sure its reporting the correct temp.
The temp sensor on the rear of the block is for the temp gauge at the cluster.
Old 05-16-2022, 01:48 PM #4
T4R Rolling Coal?
Originally Posted by HiLife View Post
Check the temp sensor at the back of the block. Make sure its reporting the correct temp.
The temp sensor on the front of the block is for the temp gauge at the cluster.
Umm, unless things changed my 97 front sensor is for the Puter and the single wire rear sensor is for the dash.
OP:
Does your PCM read 10AFR or do you have a stand alone AFR sensor reading 10?
That code is the pcm telling you there is something with the pre cat sensor or it’s wiring. Which makes sense based on what you’re describing.
Do a once over on your wiring and if nothing is frayed or melted I’d replace the pre cat O2 sensor.
Old 05-16-2022, 01:56 PM #5
Real Name: Steve
Real Name: Steve
Thanks guys. It's my UEGO / aftermarket wideband AFR gauge that is pegged down at AFR 10 when the truck goes into this mode. I just started it up and within 5 mins it was doing this again -- it used to happen after ~30 mins but now it's happening much more quickly. The dash temp gauge appears to work properly as does the temperature reading I'm getting with the ScanGauge II. It's as if the truck thinks it needs to add a lot more fuel than it really needs and keep in mind it has oversized injectors and the AEM FIC-6 which left unaltered by the AEM would run the truck super rich, too.
Old 05-16-2022, 04:21 PM #6
Doh, thanks for pointing out my confusion. I corrected my post.
Old 05-16-2022, 09:30 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Yeah, something is wrong! The larger injectors would not cause the engine to run rich as the stock ECU even with no piggyback will adjust for fueling without throwing a code and keep a 14.6 AFR in closed loop driving. I would scratch the injectors off the list of things to check. That leaves the AEM unit, the wiring, or the front A/F Ratio sensor. I have had wiring go bad on me before even though I soldered and protected it so I would take out your wiring harness for the AEM and resolder your O2 sensor wires and see if that fixes the problem. If it does not, your last option would be to replace the front A/F Ratio sensor which costs around $150 or replace the AEM unit - which is no longer in production.
326WHP 347TQ
afr , start , starts , t4r , truck
China's 2020 coal output rises to highest since 2015, undermining climate pledges Nobody Special Off Topic 8 01-26-2021 09:34 AM
20th Annual Coal Mine Cruiser Classic Registration is now open! SteveNJ Northeast 1 05-16-2019 09:56 AM
Canary in the coal mine for my water pump? StreetCreeper 3rd gen T4Rs 29 05-28-2017 08:42 PM
GCLC- Coal Miners Cruiser Classic June 15-15 lipek Off-Roading 10 06-15-2015 10:25 PM
Jan 5th 10AM Windrock Park & Coal Creek OHV ugamurph Off-Roading 2 01-07-2013 05:05 PM
