Old 05-16-2022, 11:36 AM #1
Paulmaz's Avatar
Paulmaz Paulmaz is offline
Paulmaz is on a distinguished road
Paulmaz's Avatar
ABS Light
Hello-
4R has been great, but one day ABS light went on, along with Speedometer not working and E-brake light on. Checked fluid, is good.
Took to my very honest and reasonable mechanic, and he could not get codes off of it. He replaced the speed sensor to no avail.
He believes it is the ABS Pump, and maybe even the ECU. He is looking at options as not to spend $2k on a new pump. Any thoughts or opinions on this?
This is my son's first car, and so far it has been great! we just replaced all the suspension.
2002 4Runner 2WD
292K miles and counting!
Some Pics
Paulmaz is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 12:23 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Paulmaz View Post
Hello-
The ABS codes have to be flashed. They cannot be read through the OBD2 port. A quick search pulled up this procedure: https://www.toyota-4runner.org/230426-post9.html
Old 05-16-2022, 01:09 PM #3
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Hello-
Lots of info on site for this, is the VSC Trac lights on ?
Speedo not working points towards the VSC/Trac module. Speedometer/Odometer Not Working + Related Warning Lights (P0500)
Old 05-16-2022, 01:32 PM #4
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Hello-
Don't replace the pump until you check the inputs. It's probably a free fix. Did he check the abs speed sensor harness. They have a tendency to break if you don't pay attention and let it hang working the suspension.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 10:29 AM #5
Stephen941 Stephen941 is offline
Stephen941 is on a distinguished road
Skid computer
We had our speedometer go out and ABS light also, it was the "Skid computer" which is located on the left of the driver's footwell, like to the left of the brake pedal, and up a bit. We ordered a used one off ebay, and it resolved the problem.
Stephen941 is offline   Reply With QuoteReply With Quote
Old 06-22-2022, 11:33 AM #6
Paulmaz's Avatar
Paulmaz's Avatar
Fixed!
I know this is an old thread, but thought I would provide the resolution for all! I ended up buying a used ABS Controller on ebay for $220 and the mechanic installed and programmed it, and all is good again! Speedometer working, and all check lights off.
Ended up the ABS controller was not the original, and I guess went dead.
There were cheaper ones on ebay, but this one had a 90 day warranty and his feedback was very positive, and he sells a lot of controllers. So i thought it was worth the extra $$$.
2002 4Runner 2WD
Some Pics
Old 06-22-2022, 05:52 PM #7
McLoven1t562 McLoven1t562 is offline
McLoven1t562 is on a distinguished road
you talking about that ABS Module that's down by the kicker panel on the passenger side under the dash???? silver with green toyota stickers says like AISIN and the numbers
McLoven1t562 is offline   Reply With QuoteReply With Quote
abs , great , light , pump , replaced
Help! 260k miles, check engine light, multi terrain light, and slip indicator light dave_b 5th gen T4Rs 21 01-19-2021 09:20 AM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Please help - Engine shut off + Battery light, A/T Fluid light and OIL light Lamer 3rd gen T4Rs 11 09-03-2018 06:04 PM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
