Old 05-17-2022, 07:08 PM #1
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Anyone using Soronan's Rear Sway Bar Bracket?
So I saw that Soronan had a relocation bracket for the rear sway bar and bought it out of excitement... Looking at it in person though I am not really sure how to install it. I mean I think I do but a photo would be helpful lol.
Anyone using it?
Old 05-17-2022, 07:49 PM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Anyone using it?
https://www.toyota-4runner.org/3647490-post465.html
JZiggy is offline   Reply With QuoteReply With Quote
Old 05-18-2022, 12:55 PM #3
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
Originally Posted by JZiggy View Post
What is the consensus on using these for a ~2 rear lift? (OME 890s)
Would that raise the sway bar too high? I am trying to figure out the best combo of link length and bar height to clear the e-locker.
Should the sway bar arms ideally be parallel to the ground?
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 05-18-2022, 01:01 PM #4
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Sway bar should be flat as practially possible. Issue with longer links is hitting the LCA at full stuff. I went back to Stock links with my 1.5 inch rear spacer lift. I am running stock links with 906 rear springs right now. I also have an E-locker.
Do you have a Panhard Correction? That is going to be more important to control body sway as it centers the axle and prevents the bucking or rolling of the rear in turns.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 05-18-2022, 04:18 PM #5
JZiggy's Avatar
JZiggy's Avatar
Mine's a 2" lift and this setup works fine. The sway bar endlink is not perfectly perpendicular to the mount on the frame (b/c the bracket moves the bar toward the back of the truck a bit) but I don't think that matters so much. The sway bar is pretty flat and is unable to impact any other suspension parts.
Old 05-18-2022, 06:24 PM #6
GhostRing's Avatar
GhostRing's Avatar
@shadow247 good call on the PHC kit as I currently am still on factory points.
I'm not sure I need both ends altered, but anything to make it more level can only help.
@JZiggy thanks for the info on lift height clearances. I've been kicking around too many
ideas involving cutting and re-welding mounts and other diy bracketry nonsense...
Build Etc...
Old 05-18-2022, 07:03 PM #7
jross20's Avatar
jross20's Avatar
Jzig! How's it going man? Checking this out now.
Old 05-19-2022, 11:23 AM #8
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
Not the greatest pic but you can see it in one of my posts. It is intuitive how installs once you are looking at it.
https://www.toyota-4runner.org/3535740-post170.html
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 08:59 PM #9
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
I just took my brackets out. They put the sway bar links at a really poor angle, like this (look at the bushings!):
Without the relocation brackets, the geometry is much better:
The only advantage I see to these relocation brackets is that they create more clearance between the sway bar and the e-locker actuator. But then again, a lift does not change the arc in which the suspension travels, only the resting position - so if Toyota thought that there is enough clearance at factory height, that should still hold with the 2" lift (it's the same as 2" of suspension travel from stock).
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 10:37 PM #10
JZiggy's Avatar
JZiggy's Avatar
If you shorten the link that misalignment is less severe. My links are a bit shorter than stock and it's not so dramatic as that.
Old 05-19-2022, 11:42 PM #11
official vendor
official vendor
True, I can see that - but it's still not perpendicular to the bracket, the bushings are compressed at an angle. And did Sonoran say to shorten the links? That seems like above and beyond what most folks would do. I'm somewhat struggling to understand the point of this relocation, maybe I am missing something.
Old 05-20-2022, 01:09 AM #12
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
worked good for me when I did a 3 inch lift on one of my past rigs. got the bar away from my e locker stuff, I think i even used stock links...well maybe not...its been a while..something like stock front links from a 2nd gen...i dont remember
Old 05-20-2022, 09:19 AM #13
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
From their website:
"You MUST use stock length rear 3rd gen 4Runner end links. Those are actually a bit too long already so your longer than stock links are not going to work."
"We have ONLY tested this part with the front coils from an FJ80 Land Cruiser. I have no clue if it will work with other coils. We have not tried it with anything else."
I interpret that to mean that you need about 3-4 inches of lift in the rear and stock links for the geometry to be good.
Old 05-20-2022, 09:56 AM #14
official vendor
official vendor
Originally Posted by Bad Luck View Post
From their website:
That sounds right. My stock length rear links, combined with a 2" lift, created the terrible geometry I showed above. And @JZiggy 's setup worked with a 2" lift and shorter than stock links.
So yes, I can see this system working with stock rear links and a 3-4" lift.
Old 05-20-2022, 11:58 AM #15
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
No affiliation what so ever, but the overland custom designs links sure work really well, and are adjustable if another option is needed.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
bar , bracket , install , rear , sway
Rear Sway Bar Bushing Bracket Install ScarfaceT4R 5th gen T4Rs 15 03-10-2021 12:54 PM
Sonoran Steel Rear Sway Bar Adj Bracket Ride_Red 3rd gen T4Rs 6 06-19-2018 12:11 PM
Welding a new rear sway bar bracket on? insaniak Maintenance/Detailing 0 01-19-2018 09:35 PM
ISO: Rear (anti)sway bar bottom bracket DRCocaCola 5th gen T4Rs 2 11-20-2017 09:57 PM
Rear Sway Bar Bushing/Bracket Volley 3rd gen T4Rs 8 04-11-2012 12:04 PM
