Old 05-19-2022, 08:36 PM #16
spartacus's Avatar
spartacus's Avatar
Originally Posted by clanofwolves View Post
I replaced the Idle Control Valve and she drove it and noticed it not stalling, but still hunting a bit at lights while the break is on in drive/stopped/idle. So it is better, but is there anything else I should look into?
Thanks so much guys!!
Glad you got it sorted. The other component that might be out of spec is the maf, some do go bad. Also vacuum leaks.
Old 05-20-2022, 07:58 AM #17
clanofwolves's Avatar
clanofwolves clanofwolves is offline
clanofwolves is on a distinguished road
Originally Posted by Bad Luck View Post
I would give it a few days of driving to see if it goes away. Sometimes it takes a few trips for the ecm to relearn for a new part like that.
I thought, and hoped, the same thing so I told her to drive it a few times, then let me know how its running.
"Family and God - that is what's important. Money, cars, those are things that come and go."
clanofwolves is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 08:02 AM #18
Yeah, I have had MAF issues with my oldest daughter on her Chevy (that car sucked as a reliable vehicle and somehow destroyed them, along with transmission issues (don't get me started)). This one always looks fairly clean and I hit it with a short blast of MAF sensor cleaner every few years... and she doesn't throw a code like the Chevy did. As far as vac leaks, maybe I'll spray a little starter fluid here and there and see if anything ups the throttle. There are a few vac lines that might be original, but the main ones (like brake booster) I changed out years ago, nothing looks cracked, but one never knows as air can move in tiny gaps 'eh?
Old 05-22-2022, 10:05 AM #19
Stephen941 Stephen941 is offline
Stephen941 is on a distinguished road
Could be the coils
I had a similar issue and it turned out to be not the spark plugs but the spark plug coils. Best of luck.
Stephen941 is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 08:30 AM #20
Wow, now that's another possibility. Did it throw engine light or codes? How did you diagnose it?
Old 05-23-2022, 08:32 AM #21
Found this... not sure why I wouldn't get a misfire code, but I can Ohm them regardless.
Coil Pack Testing for 2000 4R 3.4L?
Old 05-23-2022, 10:58 AM #22
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
When you check the coil packs make sure to test them cold and hot. I had a coil pack that only failed when hot and it never measured out of spec. Compare the resistance values of the coil packs to each other to help identify a bad coil pack.
engine , issue , maf , sensor , stalling
Rough Idle, Check Engine Light joeflem 3rd gen T4Rs 56 03-23-2021 07:25 PM
Idle issues .... No check engine light... Please help foxbody311 3rd gen T4Rs 2 07-09-2015 08:48 PM
'04 4runner rough idle & check engine light fable 4th Gen T4Rs 6 06-18-2014 12:58 PM
check engine light, rough idle? tonyjclark44 3rd gen T4Rs 3 02-17-2012 09:44 AM
check engine light, high idle, light shaking?? lindseymarie General Discussions 4 03-08-2011 12:13 AM
