Old 05-19-2022, 03:02 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
How hot does the transmission tunnel get?
I'm starting to put sound deadening on my 4runner. A major source of noise is engine and transmission noise. I want to put sound deadening on the transmission tunnel (in the interior).
I had a family member use my car before I started work and by then the metal surface of the transmission tunnel (from inside the vehicle) was too hot for me to touch. The stuff I have (Noico) says its good up to 212 F for extended periods of time. Is that too low for what I want to use it on? (manual transmission)
What is a sufficient temperature rating for sound insulation used on the transmission tunnel?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 03:42 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The transmission tunnel gets very hot, but that will be a sufficient heat rating for your sound deadening material.
Old 05-19-2022, 04:17 PM #3
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
I have used Noico on the inside around the trans tunnel. It's fine and it does help.
JZiggy is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 01:43 PM #4
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I'm about to add several layers of Foil Tape to my trans tunnel and console.
I already have a layer of the NOICO Foam on the trans tunnel.
Slow Crawling for hours gets the trans tunnel VERY hot. My stainless cup gets almost too hot to touch on the bottom after a full day of trails in 4lo...
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 02:21 PM #5
JZiggy's Avatar
JZiggy's Avatar
This stuff seemed to help for me. I think it will help reflect the heat from the trans and the cat more than just insulate like Noico would.
https://www.toyota-4runner.org/3673401-post495.html
Old 05-20-2022, 04:23 PM #6
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I fitted it yesterday, it does help with the noise. The stock insulation used in the footwells was disintegrating but I kept it.
I still have a lot of engine noise coming in from the firewall, but getting access requires removing large portions of the dash. I really want to cut down on noise in the 3k rpm range since that is what the engine is at on the highway.
Old 05-20-2022, 09:03 PM #7
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
wouldn't this reflect the heat back to the tranny?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 09:31 PM #8
JZiggy's Avatar
JZiggy's Avatar
The radiant heat, sure. I’d be willing to bet the trans relies mostly on convective heat transfer from the bottom and sides of the housings where there’s airflow.
deadening , noise , sound , transmission , tunnel
Driveshaft tunnel rattle? MichBadger 5th gen T4Rs 4 10-24-2021 04:06 PM
Transmission tunnel storage Rushingman 4th Gen T4Rs 6 06-18-2016 11:51 PM
Light in the diesel tunnel dekeman 5th gen T4Rs 46 06-28-2015 11:09 AM
tunnel roll driffter33 Off Topic 3 10-19-2010 05:52 PM
Wind Tunnel!!! Buckfever 4th Gen T4Rs 11 03-17-2007 02:48 PM
