Old 05-19-2022, 04:09 PM #1
dbgnallRWD's Avatar
dbgnallRWD dbgnallRWD is offline
Real Name: Darren
dbgnallRWD is on a distinguished road
dbgnallRWD's Avatar
Real Name: Darren
Front Strut Agony
Hey ya'll - I am working on replacing my front struts and got into a pickle. I got one in just fine. On the second the hard to reach bolt in the back (top of strut) was fully stuck. I broke the tong off a wrench tugging on it. Then stripped it then cut it off. I had to cut just above the built in washer due to the tight space and I was cautious about damaging the mount.
Whats left is the build in washer and now I cant get it to budge. Possibly the top of the strut is stuck on there too. I have tried banging on that washer piece with a file to try to pop it off. I was wondering about compressing the coil and pulling the shock out and then the coil would hang free - might give me more ways to wack on it.
What would you do? Thanks!
It's a 2000 4Runner SR5
Front Strut Agony-img_3429-jpeg
dbgnallRWD is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 07:22 PM #2
willyd520's Avatar
willyd520 willyd520 is offline
willyd520 will become famous soon enough
willyd520's Avatar
I'd get a Dremel in there with a sanding attachment and see if you can grind it down to the point you hit the top of the coil housing.
willyd520 is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 08:08 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
That is not a washer. It is a flanged nut so there will still be threads in that piece left there.
I'd try getting a cold chisel under that and see if you can pop it off. Of course grinding a little lower will help too.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 10:50 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
those rear bolts can be a pain....and you might not like my fix...
so 4runner #2 was a pos. all kinds of issues and rust. the shocks were shot. I had a set of 99 talls with shocks that only had about 30k on them ( I had gone to a 3 inch lift). Knowing that I had springs and shocks for all corners...with the fronts stilll assembled as a unit.. I went to switch it all front and back. I ran into the same problem. Knowing that this rig was gonna go down the road when I found a replacement...I took a sawzall to the inner fender so that I could come straigh down on it from within the engine compartment with a large drill bit and drill it out/off.
others I had issues with too, but only that one front side I had to play that game. I had to cut the rear shocks off too to get them out...again rust
othewise if you can get a grinder to it....even a small metal grinder on a dremel or die grinder...that might work too. I did not have those at the time and I was pissed and wanting to get it done. I was so pissed with this rig its issues and the rust it went on sale the minute I found 4runner #3 a super clean rust free highlander 3rd gen 4runner..
Old 05-20-2022, 11:06 AM #5
dbgnallRWD's Avatar
Real Name: Darren
dbgnallRWD's Avatar
Real Name: Darren
F-YA! The Dremel did it!!!!
I felt like a dentist in there with the drill and the mirror. Only took about 3min
of shaving it down and then the "built in washer" ring just popped off.
Thanks everyone!
Old 05-20-2022, 11:56 AM #6
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Good job! Patience wins the day on this sort of thing.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
front , strut , stuck , top , washer
Why is my removed OEM front strut longer than my new OEM front strut? BigDummy 3rd gen T4Rs 10 12-30-2020 10:03 AM
Front strut top nut cpark_12 4th Gen T4Rs 2 09-16-2014 10:38 AM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
front strut t4r4life 3rd gen T4Rs 4 02-09-2010 02:51 AM
Stop the Agony! Lexusbstrdchild Off Topic 5 01-21-2005 01:56 AM
