Old 05-20-2022, 02:49 PM #1
Donny1 Donny1 is offline
Donny1 is on a distinguished road
Do I Have Fog Lights?
My front bumper has round lights next to the blinker that always came on with the running lights. There is no rocker switch to the left or on the turn signal stack for fogs.
Are these just a running light? I just installed a Shrockworks front bumper and tried to use the wiring from them to a running light but there is no power there with a test light.
Any clues? I know the lights I got work because I powered them and they come right on. I did read something about DRL's using PWM signals that may not read on a dmm or test light but not sure if these are fog, running, or DRL's.
Thanks for any help in advance.
Donny1 is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 03:42 PM #2
Back4More Back4More is offline
Back4More is on a distinguished road
Check the stalk on the left of the steering wheel. You should have a rotating switch for your fogs. Yes, it sounds like you have fogs.
Back4More is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 03:51 PM #3
No, I have a 2000 2wd with the switch on the stack, this one has nothing for a switch. I did check the relay center and all slots are full.
Old 05-20-2022, 03:56 PM #4
interesting...i had an 00 4wd limited and didn't realize they were different. My 98 had the switch.
Old 05-20-2022, 04:04 PM #5
I've only had this a short time but I'm pretty sure they were always on when the headlights were on and went off when the high beams came on.
That's why I thought they might be DRL that have a PWM signal.
Confused.
Old 05-20-2022, 08:29 PM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Confused.
Can you post a picture of your turn signal stalk?
Old 05-20-2022, 09:45 PM #7
Not until next week, wife is out of town with the truck.
But the turn signal stock does not have a second ring to turn, just headlights. My 2000 has the other type with the ring so I know the difference.
Old 05-20-2022, 11:12 PM #8
Real Name: Patrick
Real Name: Patrick
DRL’s are part of the headlights and are not wired from the factory into any other light. The fact that the lights in the bumper turn off when the high beams come on indicates that they are fog lights or at least function the same as fog lights. It’s possible a previous owner added the fog lights to the prewired fog light connectors, added the necessary fuse, then figured out a way to send power to the fog light signal wire without the switch (or added a switch somewhere else that you haven’t found yet.)
Old 05-30-2022, 06:07 PM #9
It will forever remain a mystery
I spoke to the previous (original) owner and in fact they always were on with the low beams like I noticed. Nothing has ever been replaced or modified. It has the relay, fuse and lights in the bumper but no switch.
I verified both powers to the relay and jumped power from the relay terminals and the wiring and lights work fine. It is not receiving a ground to activate the relay..... because there is no switch to turn them on! Whatever, lol. They have been wired to my ad on fuse box as a marker/running light.
Moving on now.
Old 05-30-2022, 11:58 PM #10
SLOrunner87 SLOrunner87 is offline
SLOrunner87 is on a distinguished road
I’m pretty sure all trucks are pre-wired for dogs.
SLOrunner87 is offline   Reply With QuoteReply With Quote
Old 05-31-2022, 10:28 AM #11
Real Name: Patrick
Real Name: Patrick
I've never seen a dog plug in before...
96-98 are not prewired for fog lights. 99-00 base models are hit or miss on fog light pre wiring.
drls , light , lights , read , running
New SAE driving lights, stealth bars, and ditch lights by Diode Dynamics mynameistory 5th gen T4Rs 27 01-24-2022 05:05 PM
Hooking up Rack lights to Puddle Lights (With Meso Customs switch) Peepew 5th gen T4Rs 1 12-15-2020 07:36 PM
98 4runner headlights, bumper lights, and corner lights. OEM good condition. chaskins77 For Sale: T4R Items 4 08-28-2012 01:14 PM
Fs: 3rd gen tail lights, corner lights, turn signals, 3rd brake light set with led Stretch1100 For Sale: T4R Items 0 10-06-2011 03:42 AM
Couldn't yiu just turn the front bumper running lights into auxilary lights? Muti007 3rd gen T4Rs 6 05-03-2010 12:48 PM
