05-28-2022, 12:58 AM
I'm replacing the AC compressor, what else is good practice to replace with it?
I'm replacing the dryer, expansion valve, compressor, all the rubber seals
Is there anything else that is recommended to be replaced along with those items?
05-28-2022, 07:37 AM
That covers it (as far as I know from a DIY perspective).
IF you're replacing due to failure, you may want to run some line cleaner though each section. I think they're called "flush kits" and are a pressurized gas that cleans out any physical contaminates (metal that could destroy the new compressor). I only just learned about this while researching getting one of my vehicles AC back up and running.
05-28-2022, 08:01 AM
Real Name: Mark
Real Name: Mark
Check the tensioner bearing only thing I can think of.
05-28-2022, 05:48 PM
Pull a vacuum on the system to remove moisture and contamination if you feel like it.
05-28-2022, 06:03 PM
Real Name: C8H18 Mike
There's a write-up on here that lists all of the parts in the process required, it is rather extensive if you want to do it to factory new condition.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
05-28-2022, 10:20 PM
Real Name: Patrick
Real Name: Patrick
Pulling a vacuum is required anytime you charge an ac system after opening it or recovering the refrigerant
05-28-2022, 10:45 PM
I know luckers. The if you feel like it was a little sarcastic. I just installed a new HVAC system in my mom's house saved her about five grand. I'm aware. I appreciate you keeping an eye on me though 😘
05-28-2022, 11:08 PM
Don't forget the correct amount of PAG oil.
05-29-2022, 12:42 AM
Real Name: Patrick
Real Name: Patrick
The “if you feel like it” implies that pulling a vacuum is optional when it’s actually a requirement. I’m clarifying that for anyone that comes across this later.
05-29-2022, 04:04 AM
I’d replace both Schrader valves also.
05-29-2022, 08:58 AM
I think you need to remove the evaporator to change the expansion valve, its not fun to get out from under the dash and usually a culprit for a leak so you may consider replacing it as part of the job since your doing the expansion valve. There is a list somewhere in the FSM that tells you the amount of PAG oil needed to add for each component that is removed
05-29-2022, 11:21 AM
Real Name: Mark
Real Name: Mark
As deep as your going get a new condenser they're all old by now.
05-29-2022, 01:34 PM
I believe
@ JerkyDrewster
replaced his entire AC in his 99 before he rolled it. I don't have the energy or search skills to find the post but he listed all the part numbers, some of which were available on Amazon at the time
Attachment 396463
05-29-2022, 03:51 PM
Real Name: Drew
Real Name: Drew
Originally Posted by octanejunkie
I believe
@ JerkyDrewster
Attachment 396463
I think you might have me confused with someone else! I think the most I did to my AC system was a standard recharge. My wife's old Civic had 3 compressors replaced in 2 years though...
1999 Black SR5 Highlander 4wd V6 Automatic ( Build Thread)
2001 Millennium Silver SR5 Sport 4wd V6 Automatic (Build Thread V2)
05-30-2022, 02:07 PM
Real Name: Patrick
Real Name: Patrick
I believe
@ JerkyDrewster
Attachment 396463
I think you are thinking of bamadrewski's ac write up DIY Complete AC Replacement on 2000 T4R Limited
Your attachment doesn't work by the way.
