Old 05-22-2022, 04:56 PM #1
Wasatch Rebel Wasatch Rebel is offline
Wasatch Rebel is on a distinguished road
My 2000 rocking right to left at speeds above 65
I may have asked about this before, but can't find the thread. I'm having trouble with this happening and it's more pronounced when there are several people in the vehicle, or just me, but lots of weight in the back. I'm thinking it's probably the rear control arm bushings. Can anyone give me some insight here?
Wasatch Rebel is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 05:18 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Probably ALL the control arm bushings. I noticed a VAST improvement with each item I swapped out, down to and including the panhard (which solved the last of my side to side sway)
Brian. is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 06:35 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree with the other member. It's either the bushings or loose control arm bracket bolts unless your brackets are extremely rusted and moving. As when mine was doing it I had 2 loose control arm bolts...
Old 05-22-2022, 10:28 PM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
This one?
Wobbling issue in my 2000
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 11:08 PM #5
nissanh nissanh is offline
Could it also be a worn out U joints?
I replaced all suspension bushings in my 4R with OEM parts, and now, it rides as good as my brand new Taco.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 05-22-2022, 11:31 PM #6
Originally Posted by Dezert4Runner View Post
Yeah. Thanks. I don't know how to find those older posts apparently.
Old 05-23-2022, 09:30 AM #7
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Concur on the suspension bushings, with an emphasis on the panhard rod. A couple of years ago while returning from our Colorado/Utah trip, with lots of wheeling involved, my 4Runner had a new trick - a slow side to side wobble at higher speed son the highway. Usually initiated by a road heave or bump. Nice and slow, and not increasing in intensity, but certainly unnerving. I had to double and triple check to make sure I wasn't subconsciously doing it via steering wheel input (I was countersteering to try and stop it). But no, it was all the truck's doing. At the next gas stop I wiggled the truck vigorously side to side, trying to spot a loose bushing, didn't see anything. Kept driving it home, and learned to do a sort of long curve (in the lane) to 'reset' it when it got started.
A week or two later after going through the rear end (HD lower control arms with poly bushings, newer upper OEM arms, SS adjustable panhard rod with poly bushings) I discovered that there was a slight bit of wear on the panhard rod bushings, maybe enough for about 1/4 inch of movement when pushed hard? So little it looked like normal bushing deflection to me. I replaced them and... wiggle/wobble/oscillations were all gone.
JohnMc is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 10:28 AM #8
Where is the panhard rod located? I am not great at doing much of my own mechanical work and my mechanic has it right now so I can give him a call to check that as well as the rear control arm as that sounds like my exact problem.
Old 05-23-2022, 10:59 AM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
From the back side of the rear axle to the frame. It is parallel with the axle housing.
Old 05-23-2022, 11:50 AM #10
whyzee125 whyzee125 is offline
whyzee125 is on a distinguished road
It's your rear control arm bushings. Not a common issue on these trucks so not super well known like the steering rack bushings but that is your issue
Originally Posted by LittleCaesar View Post
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
whyzee125 is offline   Reply With QuoteReply With Quote
Old 05-25-2022, 11:28 PM #11
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
had this happen to me on my 98 sometime in december, was shaking horribly between 50-70mph, turned out to be tires thankfully, i was dreading the control arms. might want to look into that if possible, you might get lucky.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
bushings , give , insight , people , vehicle
WTB 2000 SR5 left rear door - Denver area WRfarmer Want to Buy/Trade 0 02-26-2019 11:05 PM
WTB 2000 SR5 4Runner Rear Left Bottom Seat BMOR1991 Want to Buy/Trade 0 01-12-2018 11:30 PM
Weird noise at high speeds on a 2000 mikePerreman 3rd gen T4Rs 2 06-21-2017 10:43 AM
2000 4Runner runs poorly when left outside overnight jtes1226 3rd gen T4Rs 0 06-05-2016 07:21 PM
