Old 05-22-2022, 09:12 PM #1
dbgnallRWD's Avatar
dbgnallRWD dbgnallRWD is offline
Real Name: Darren
dbgnallRWD is on a distinguished road
dbgnallRWD's Avatar
Real Name: Darren
Oil in an air tube???
Hey ya'all.
I am deep into a valve cover job and have a couple questions (just one for this post). I removed a hose that goes into the air housing just before the throttle body. Photo of the tube below. You can see even the outside of it looks oily. Inside this tube and just inside the area it goes into was oil.
I don't think that oil should be there??? Does anyone know how that could happen or what it means for the car. There was also what I judge to be burnt oil residue inside the plenum.
Just seems weird. Thanks for any thoughts.
Oil in an air tube???-img_3440-copy-jpg
dbgnallRWD is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 09:52 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Oil from the PCV outlet a few inches away. Weird it's somehow traveled upstream but I think I vaguely recall mine having a little bit in there last valve cover job. At any rate I'm willing to put money down on that being the cause
Old 05-22-2022, 11:10 PM #3
nissanh nissanh is offline
How is the PCV valve grommet and the hose? If you haven't replace those, try those (use OEM).
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 05-23-2022, 01:14 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
def replace pcv valve and grommet, and if your doing valve covers, good time to do the grommet as they ae brittle and often break ip dropping little chunks into the valve system, so doing it while vc off you eliminate that. Also use OEM as they will last years and you wont have to do again for a long time.
and remember the vc bolts are torqued to inch pounds...not foot pounds...no fun breaking off a valve cover ear and having to find a replacement
Old 05-23-2022, 04:48 PM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's the vent hose for the PCV system (positive crank ventilation). Oil vapors are supposed to be directed back into the engine to be burnt off rather than vented to the atmosphere to reduce emissions. It's completely harmless just old and dirty. Like others said you'll want a new PCV valve and grommet and just give that particular hose a good clean. Chances are your throttle body is going to look rather black as well.
326WHP 347TQ
Old 05-23-2022, 05:06 PM #6
As was said, that is a crankcase vent hose. Normally the fresh air inlet for the engine (opposite head from the PCV valve), but can have vapors come out if there is a lot of blow-by, high load or a clogged PCV valve/hose.
Not 100% normal, but not the end of the world. Clean it up, replace the PCV valve, grommet and hose to start and see if it comes back after a clean up.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-23-2022, 09:19 PM #7
Real Name: 3 Bears
Real Name: 3 Bears
another side note.... your ICV might be getting gunked up now as well. Its up stream of that hose on the bottom of your throttle body. I have read where many just spray junk into the throttle body to clean it up....for looks...but that gook has to go someplace...and often drains into the ICV which than gunks that up The ICV is not hard to service esp if you pull off the throttle body. clean it real well. rotate the shaft and clean more.. its one more simple gasket that even napa sells....if not others. The pain is the screws that hold it on. A JAS screwdriver helps....yes it looks like a Phillips head...but has a slightly different cut to it. ( guess the JAS means Japanese something could not think of a word for the "A" or the "S" other than ahole screw) Even timmy ( videos) talks about how important in some applications a JAS screwdriver is.
Old 05-24-2022, 12:17 AM #8
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
JIS = Japanese Industrial Standard
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 05-24-2022, 04:53 PM #9
dbgnallRWD's Avatar
Real Name: Darren
dbgnallRWD's Avatar
Real Name: Darren
Thanks everyone for your input! I did indeed replace the PCV valve and grommet.
air , inside , oil , plenum , tube
Step tube and tube rack. balajij 4th Gen T4Rs 21 01-22-2019 02:08 PM
WTB: 4th Gen OE Tube Steps, OE Tube Roof Rack, 5th Gen 17" wheels j_h_cole Want to Buy/Trade 0 02-18-2015 05:04 PM
WTT: 2009 Tube Steps for Urban Runner Tube Steps halohaloboy Classifieds - buy & sell (no commercial ads please) 3 05-16-2010 12:10 AM
WTB 2006 + Tube Steps, Tube Rack & LED Taillights Mpower3 Classifieds - buy & sell (no commercial ads please) 0 02-23-2010 01:30 PM
