Old 05-24-2022, 07:07 PM #1
svaero svaero is offline
svaero is on a distinguished road
Keep blowing brake light fuse
My 2000 SR5 4x4 keeps blowing the tail light fuse. I thought it was the brake switch but it tests good. I've replaced all the brake lights and check all the wiring for any chaffed areas. The brake lights work fine in park and I can feel the brake lock solenoid going in and out. As soon as I shift out of park with my foot on the brake the fuse blows. Could it possibly be the brake shift computer?
2000 4Runner SR5 3.4 V6
svaero is offline   Reply With QuoteReply With Quote
Old 05-24-2022, 08:15 PM #2
spartacus's Avatar
spartacus's Avatar
There is an interlock solonoid that gets power to release the shift lock. Trailer wiring controller or plug corroded. Check the wires in the rubber boot for the wiring to the hatch. 3rd brake light bulb contacts corroded, if you've already checked the brake light holders for corrosion.
Old 05-24-2022, 08:38 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sounding to me like a dead short in the stoplight circuit. If it's shifting out of the interlock for park the brake switch is working. I suspecting a broken wire in your 3rd brake light as well. Or it's shorting against ground blowing your fuse.
Old 05-24-2022, 09:31 PM #4
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
A problem well-stated is a problem solved.
Care to clarify what is really blowing? Brake light fuse as in your post title, or
tail light fuse as in your description? Those are two different fuses supplying different circuits.
My 2000 SR5 4x4 keeps blowing the tail light fuse. ..
However, title says "Keep blowing brake light fuse"
As soon as I shift out of park with my foot on the brake...
This step ^^^ turns on daytime running lights, IF you have any.
Do you have daytime running lights? Does problem occur whether engine is running or not?
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
Last edited by RAD4Runner; 05-24-2022 at 09:37 PM. Reason: Brake light fuse or Tail Light fuse?
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 05-24-2022, 10:58 PM #5
Sorry for the confusion. It's only the brake light fuse that keeps on blowing when I shift out of park with the engine running and my foot on the brake. And yes, I have daytime running lights.
I have the entire back of the car opened up to access the wiring. I've checked everything I can get to and I've replaced all three brake light bulbs. When I'm in park with the engine running, I tap the brake and all three brake lights illuminate and I can hear and feel the shift solenoid moving in the shifter. I then move the car out of park and I can hear the brake light fuse blow.
The brake circuit is separate so why is the brake light fuse blowing when I move out of park into reverse which is not part of the brake light circuit?
Question - On the inside of the left rear quarter panel is a black box about the size of a deck of cards stuck to the inside of the quarter panel. It has wires going into the top and out of the bottom. I can't find anything that tells me what it is.
Could it be that there's a short in the neutral safety switch?
Old 05-24-2022, 11:25 PM #6
As I said, I replaced all three brake light bulbs. The 3rd brake light socket look like it had gotten hot because the white plastic was a light brown color but the socket looked ok inside. I unplugged the socket at the connector and it still blew the fuse. The other brake light sockets looked fine.
I don't think I can shift out of park without the engine running. Kind of hard to test right now.
I unplugged the two large connectors in the ceiling of the cargo compartment to the left of the cargo light. None of the rear lights worked anymore and when I started the car and shifted out of park with my foot on the brake the fuse did not blow.
I have stock trailer wiring. Several months ago I rented a trailer to bring home a new Harley. Could something have happened to the trailer circuit? The plug looks fine.
Old 05-25-2022, 08:24 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can unplug the trailer harness box to rule it out. The stock one is in the driver side behind the big plastic panel near the real tail light. If aftermarket, they are on the passenger side tail light as mine oem blew and the aftermarket is the opposite tail light.
Old 05-25-2022, 11:39 AM #8
davidch davidch is offline
davidch will become famous soon enough
I had a similar problem and, like others here, found that the factory trailer light "multiplexer" was the faulty component. Mine had visibly distorted due to heat of an internal short. I recalled when I diagnosed the problem that a week or so earlier I'd smelled "hot plastic" while driving.
The OEM item is, to my knowledge, NLA and was quite expensive when it was still available. That it is NLA might speak to its frequent replacement.
I replaced it with a Hopkins 43415 kit. Amazon has 'em for $48.64. Mine has been working for over 10 years.
Perhaps replacing the OEM item with a Hopkins could be seen as a reasonable prophylactic measure.
davidch is offline   Reply With QuoteReply With Quote
Old 05-25-2022, 01:56 PM #9
I've had TWO OEM trailer light boxes go bad... Maybe even a third when my dad had it. Now on an aftermarket from etrailer (can't remember the brand).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-25-2022, 05:10 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I even have an aftermarket go bad too.. lost the turn signal circuit.
Old 05-26-2022, 07:40 PM #11
I finally found the problem. It was the tailgate wiring where the tailgate hinges. The big black wire was almost broken through entirely. I repaired the black wire where it was broken and I cut the others close to the connector and slid a piece of shrink wrap to where the insulation was broken. I didn't want any more wire splices close to where the door hinges.
Thanks to all for the help. Just talking things through with someone really helps sometimes. Kudos to Spartacus for suggesting the hatchback. I just started eliminating wire branches by disconnecting things until the fuse no longer blew. What threw me was everything worked fine until I shifted out of park into reverse. I'm still not sure how the hatchback wiring has anything to do with the backup circuit.
Anyway, it's fixed now and my wife is happy. The car only has 115k on the odometer and it's been perfect until this issue. Fortunately, I could fix it myself with a little help from my friends and toyota-4runner.org.
Keep blowing brake light fuse-img_0259-jpg
Old 05-28-2022, 01:43 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The rear hatch and your drivers door boots are probably 95% wire issues on those circuits are. Extremely common in these vehicles due to their age..
Glad you got it fixed. Good job.
Old 05-29-2022, 09:47 PM #13
SLOrunner87 SLOrunner87 is offline
SLOrunner87 is on a distinguished road
This was my issue for a long time.
SLOrunner87 is offline   Reply With QuoteReply With Quote
Old 05-29-2022, 10:44 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The Hopkins units will work. However,they can burn out too. I just lost the driver side turn signal out of mine.. if it's the same kit I got it will hook into the passenger side instead of the drivers side. So wiring will have to flip.
brake , fuse , lights , park , shift
2010 Brake/tail light issues keep blowing fuse mbshaw88 5th gen T4Rs 14 05-31-2023 12:42 PM
Tail Light/ instrument cluster light fuse keeps blowing wahoossi 4th Gen T4Rs 2 05-04-2016 12:36 PM
tail light fuse keeps blowing janthony Problems & Warranty Issues 0 10-03-2008 09:17 PM
tail light fuse keeps blowing janthony 4th Gen T4Rs 10 10-03-2008 09:02 PM
