Old 05-25-2022, 11:39 PM #1
NegroTundra NegroTundra is offline
NegroTundra is on a distinguished road
Died suddenly, cranks but no start
After concluding 500 mile road trip, filled up with gas and got within half mile of my house and it sputters and dies. Cranks, but will not start. 255k miles well maintained new spark plugs and wires at 225k. Fuel pump? Sure seems like it. How to test any electric fuses that may have something to do with this?
Thanks
00 T4R 3.4L Sc'd Locked 4x4 (140k)
98 T4R 3.4L 5-Speed Locked 4x4 (280k)
16 Dodge Ram 2500 6.7L Cummins fully deleted
NegroTundra is offline   Reply With QuoteReply With Quote
Old 05-26-2022, 12:13 AM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Thanks
How far did you drive after refueling before it died? My first thought is bad gas.
Skulking is offline   Reply With QuoteReply With Quote
Old 05-26-2022, 04:10 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+1 on bad fuel. Fuel pump or possibly the crank sensor failed. As possibilities as to why it won't run.
Old 05-26-2022, 08:43 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Did it sputter/stumble then die (bad fuel/weak fuel pump) or did it quit suddenly (crank/cam sensor failure)?
EDIT: Does the rpm gauge move or stay at zero while cranking? If it moves then you have a crank sensor signal.
Old 05-26-2022, 09:59 PM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Could also be a clogged IAC, or idle air control valve. It usually acts up when really hot and when idling at a stop light and makes the engine stall.
326WHP 347TQ
Old 05-27-2022, 01:45 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
This morning my neighbor had her 02 4Runner cranking but engine not starting. It ran fine a hour earlier. The tow truck guy took the wooden handle of a rubber mallet and banged on the side of the gas tank several times. 4R started right up and ran.
pluton is offline   Reply With QuoteReply With Quote
Old 05-27-2022, 09:30 AM #7
Real Name: Patrick
Real Name: Patrick
Sometimes you just have to smack some life into the fuel pump or starter lol
Old 05-27-2022, 09:39 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
When hitting the tank starts the fuel pump the armature is done. Time for a new fuel pump bad spot on it.
Old 05-27-2022, 10:15 AM #9
ArthurKotb's Avatar
ArthurKotb ArthurKotb is online now
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
I had a similar experience with a 2.5L V6 Camry. It happened twice, years apart. Both times it was the MAF (mass air flow sensor). Car would run fine then just stop dead; would crank but not start. Garage replaced the MAF and all was well. Second time it happened I replaced it myself.
There are some YouTube videos on testing.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is online now   Reply With QuoteReply With Quote
Old 05-27-2022, 10:38 AM #10
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Had a similar problem while on a road trip.
Started running very poorly and stalling shortly after stopping for fuel.
My initial thought was IAC or bad gas.
Ordered new IAC from local Toyota dealer as didn’t want to get stuck on my way back home, 1500 miles away.
Turned out to be bad gas, cancelled the IAC before it shipped out.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 05-28-2022, 07:43 AM #11
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Pull codes check PCM inputs.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 06-13-2022, 02:49 PM #12
Ended up being fuel pump. Back on the road now
Old 06-13-2022, 06:32 PM #13
02_SE_Runner_DAD's Avatar
02_SE_Runner_DAD 02_SE_Runner_DAD is offline
02_SE_Runner_DAD is on a distinguished road
What kind of black magic stuff is this and does it have to be a wooden handle? lol
Fly High Son(NATE) 1995-2014
http://www.toyota-4runner.org/3rd-ge...od-thread.html
02_SE_Runner_DAD is offline   Reply With QuoteReply With Quote
Old 06-14-2022, 12:24 AM #14
Real Name: Patrick
Real Name: Patrick
The contacts in a fuel pump can wear away and cause the pump to not work anymore. Smacking the fuel tank CAN potentially move the contacts in the fuel pump around enough to work for another time or two. Same concept as hitting your starter with a hammer.
cranks , died , mile , pump , start
Cranks over but won't start aldaman 3rd gen T4Rs 1 04-24-2017 06:00 AM
'Runner died after a start, now cranks but won't start ThePizzaGuy 3rd gen T4Rs 7 10-11-2014 01:10 PM
Help: Battery Suddenly Died Grape Ape 5th gen T4Rs 19 08-28-2014 07:59 AM
99 sr5 suddenly died while driving Daniel furtado 3rd gen T4Rs 11 03-01-2014 12:56 PM
