05-28-2022, 12:38 AM
Power antenna replacement
Who's done the Tacoma whip mod or a smaller knubby style? Mine finally snapped off. The antenna (motor I guess you would call it?) still works fine. I can hear the motor go up and down when the radio powers on and off. I'm not interested in replacing the OEM one as my power antenna won't manually go down with my new head unit. The easier install, the better. I'd prefer if I have a choice to not take off the bezel and do that process all over again.
This one here caught my eye and looks like a relatively easy install.
Amazon.com: AntennaMastsRus - Conversion Kit is Compatible with Toyota 4 Runner (1996-2002) - Toyota Hilux (1998-2005) : Electronics
Any other suggestions from the group? Any feedback is appreciated.
05-28-2022, 01:23 AM
Real Name: Devan
Real Name: Devan
I have a Taco antenna. I'd recommend it, works as it should and looks much better imo. Also nice to not worry about the mechanism breaking
05-28-2022, 07:49 AM
the item you linked looks like just a mast intended for the automatic motor, and may be exactly what you want/need. But the Taco whip conversion is a Completely different beast, you replace everything from the head unit (plug that fits into the HU, wire though the firewall, mount the new mast on the inner fender) on out to to the antenna you see. I did it, it was a ~2 hour job mostly due to my meat mitts being oversized and not fitting into tight places well. It's annoying, not difficult. Quality is outstanding though, as you'd expect from a Toyota part.
I suspect the easy solution is the mast you linked, but I don't know how much easier who who knows about quality or longevity. Want to do it twice?
05-28-2022, 01:44 PM
Real Name: Devan
Real Name: Devan
What do you mean? The antenna doesn't require the corresponding headunit whatsoever, i used it with the OEM one for a month or so, unless im misremembering. The only difference between the two units is backlight color and ours having plugs for an amp and secondary antenna .Should take you maybe 30 minutes max to swap out the masts themselves, wouldn't exactly call that a "beast"
05-28-2022, 04:19 PM
Real Name: Patrick
Real Name: Patrick
I think he meant “from the head unit” as in the entire cable that plugs into the head unit and not the head unit itself. Which is required if you were to replace the entire power antenna assembly.
05-28-2022, 06:17 PM
Real Name: C8H18 Mike
To install the taco whip mod antenna you need to replace the motorized base with a fixed mount base.
If your motor is still good, you can just replace the antenna assembly by feeding in a replacement antenna when you turn the radio off and you hear the antenna motor running to retract the antenna
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
05-29-2022, 02:38 AM
Real Name: 3 Bears
Real Name: 3 Bears
I think it is a neat idea. sure beats out replacing everything to do a taco whip..which I have done twice now...however for me...in the outback...it would be nice for being able to add a taco whip or any extended antenna...those stubbys work ok for flat landers and city folk
feel free to pass that on to the designer/seller
05-30-2022, 01:32 PM
The motor is still good but my antenna won't retract without powering off the truck. This is something I'd like to avoid.
05-30-2022, 01:35 PM
I'm 99% a flatlander /city driver. My signal for FM doesn't have to be "perfect". I use my Sirius XM app, But I'd still like to have some local reception when I don't wan to burn through my data plan.
05-30-2022, 01:42 PM
Originally Posted by brillo_76
I have replaced 2 power antenna mast. I can see folks wanting to just put a new whip antenna on. I just like the ability of the antenna to retract though. Turn off the radio and your antenna tucks in. That's the reason I keep them. :-)
If my radio turned off on without turning the truck off own the antenna would tuck back in, this is no longer the case with the new head unit. Instead of adding a switch and replacing the OEM antenna, I thought the stubby might suffice.
05-30-2022, 02:42 PM
Real Name: Patrick
Real Name: Patrick
If your antenna goes up and down with the motor, then adding a switch for the antenna up/down signal would be the cheapest and easiest way to go about it.
05-30-2022, 02:55 PM
Real Name: 3 Bears
Real Name: 3 Bears
I like the auto retract as well, but in winter my antenna would freeze either down or up or half in between and then you would hear the motor keep trying
05-30-2022, 03:01 PM
Real Name: N/A
Real Name: N/A
If you get rid of your power antenna motor I'd be happy to have it. My motor has had its teeth stripped and nothing can fix it.
Most of the time the motor is fine but the mast has its plastic teeth stripped. If your motor is broken you can unplug the motor when the mast is up and you won't have to keep pulling it up manually.
1998 4runner 2.7 manual
05-30-2022, 04:30 PM
Cheaper than buying a new OEM mast and whatever else i need?
