Old 05-30-2022, 05:18 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Originally Posted by Auce View Post
Cheaper than buying a new OEM mast and whatever else i need?
Does your current antenna go up and down already? If yes, then all you need is a switch to interrupt the antenna up signal from the head unit to the antenna motor.
Old 05-30-2022, 07:03 PM #17
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Absolutely. Less work, too.
I did it on my 2WD then transfer it to my 4WD along with my pioneer stereo center console bezel
If you still have the factory radio, and CD player combo, the antenna only goes up when you're using the actual radio. At least that's how mine worked. I only added the antenna switch after I went to the pioneer which raised the antenna every time I turn stereo on, regardless of function.
Around the city, I use the antenna in the rear passenger glass which I coupled together with a Y adapter and micro antenna to regular antenna plug adapter.
I have a thread on the entire modification somewhere, but a lot of people have done it
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-10-2022, 03:40 PM #18
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
blue-white power antenna lead
if the after market HU harnass came with a blue-white power antenna lead that has to be connected to a blank pin in the OE harness in order to have the antenna only work when the HU is in tuner mode..
jrm is offline   Reply With QuoteReply With Quote
Old 08-10-2022, 07:35 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Originally Posted by Pyral View Post
If you get rid of your power antenna motor I'd be happy to have it. My motor has had its teeth stripped and nothing can fix it.
Most of the time the motor is fine but the mast has its plastic teeth stripped. If your motor is broken you can unplug the motor when the mast is up and you won't have to keep pulling it up manually.
I have a motor off a 1998 that i lost the center nut. The mast is gone. Let me power the motor up and see it it works..Then if it works, I can send it to you.. :-)
Old 08-11-2022, 09:26 PM #20
revans611 revans611 is offline
revans611 is on a distinguished road
One day I turned on my radio, and the motor raised the mast and it flew completely off of my 4runner. With the radio still on, I picked the mast up off the ground, stuffed the plastic/nylon track in the hole and then turned the radio off. The motor grabbed the antenna and retracted it back into its proper place. The nut that holds the antenna to the body was loose so I tightened it, and I have had another problem with it in many years.
revans611 is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 09:41 AM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nice. I am glad it didn't mess up your mast.
Old 08-15-2022, 04:24 PM #22
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral will become famous soon enough Pyral will become famous soon enough
Pyral's Avatar
Real Name: N/A
That would be really great, I'm still looking for one
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 08-16-2022, 05:19 PM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ok. Let me verify the motor works and send you some photos..
Old 08-17-2022, 03:45 PM #24
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
want to add to my previous posts....for me on one of them...the plastic broke part way....leaving a hunk of plastic stuck on motor..so motor could not grab new piece.....so I had to take motor mechanism apart to clear out the broken piece...just be aware that it might not be just plug and play with a new mast and antenna plastic whip.
after that if I have an issue its taco whip for me......plus when its minus 40 even a new mast and plastic does not go up and down so good.....even gets stuck in any poistion...up ...down...someplace in between and the motor kept trying.
lastly...there is lots of stuff on the forum that has said that some of the cheaper masts ( plastic tail) dont work or last long.
Old 08-18-2022, 09:50 AM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You may not want this one. As I was checking it over and found this. The one bracket looks like it is cracked off..
Old 08-22-2022, 05:52 PM #26
second2none second2none is offline
second2none is on a distinguished road
My antenna snapped recently and would not retract. I got the entire unit replaced but glad I didn’t have to do it. They had to fish the wire pass the firewall and connect to back of the radio.
second2none is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 11:19 PM #27
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
I'm confused.
255K - Y2K/E - Clock still works
antenna , install , motor , power , prefer
Power antenna replacement octanejunkie 3rd gen T4Rs 9 02-28-2022 07:16 PM
Power Antenna Replacement mpm19958 General Discussions 1 08-16-2019 11:44 PM
Replacing head unit: 3 antenna input question & power antenna replacement question Rancho5 3rd gen T4Rs 14 08-24-2018 06:51 PM
power antenna replacement Crashnrondo 3rd gen T4Rs 4 05-22-2012 12:14 AM
power antenna replacement? Chadman 3rd gen T4Rs 7 12-29-2010 01:29 PM
