08-18-2022, 03:14 PM
Pulsing RPMs after cat/O2 sensor/exhaust replacement…
Vehicle: 2002 Sport SR5 - EPA emissions (non-CARB)
Recently had my rear cat stolen, and just had a chance to install the replacement parts last night (pretty much all Walker stuff). New O2 sensors (upstream AND downstream) along with the new cat and muffler. New exhaust gaskets at each joint.
Fired it up, and now my RPM pulsates. At idle, during acceleration, and during steady throttle, there’s an a consistent pulse in the RPM, regardless of where the needle is on the tach. Pulse seems to be between 50-100rpm, according to a visual check of the tach, and according to a couple different OBD reader apps on my phone. No codes are being thrown, no CEL, and per the apps, all parameters look to be good. (I have an ELM327 reader, and have used DashCommand, CarScanner, and inCarDoc apps).
Vehicle ran fine before this theft, this has appeared only after new parts install.
Despite getting no codes to suggest there being an issue, I’m tempted to get a new MAF, since a lot of folks refer to it being a culprit when tracking down RPM issues (though I haven’t read of a problem matching mine).
Any thoughts? When new O2 sensors are put in, do you have to replace other bits at the same time? Or reset anything (I’ve swapped O2 sensors before, but don’t recall resetting/changing other stuff). Do new catalytic converters break-in in such a way to that would cause this type of pulsing RPM issue?
Reason: Forgot vehicle info!
08-18-2022, 03:46 PM
my guess is that your first o2 sensor needs replacement
1998 4runner SR5
08-18-2022, 04:13 PM
Originally Posted by brillo_76
What year of 3rd gen emmisions are we dealing with?
Oops, edited above, but EPA non-CARB.
08-18-2022, 04:16 PM
I put in a brand new Denso for the upstream sensor. I can wrap my head around new parts being crap, but would that explain the specific symptoms I’m experiencing? When o2 sensors have gone bad before, I’ve at least gotten a CEL. (The downstream was an aftermarket, that what the shop had at the time)
08-18-2022, 04:20 PM
Real Name: Patrick
Real Name: Patrick
Where did you buy the Denso oxygen sensors from? What part numbers did you buy?
08-18-2022, 05:06 PM
Did you buy your sensor from Toyota, Rock auto or an auto-parts store? As its quite possible if you didn't you got a counterfeit one. Thus why it doesn't work properly.
Denso #234-9002
Purchased off Amazon last year as I had some credit I wanted to use and thought I would stockpile some regular maintenance stuffs, just never got around to doing it. Sensor has been sitting in its box ever since.
08-18-2022, 05:07 PM
Denso #234-9002
08-18-2022, 05:19 PM
I’m kinda going a through a crash course in vehicle issue diagnosing here, so I wonder if what I’m experiencing is the phenomena often referred to as “hunting”?
I just read a reference to trying to isolate the issue by unplugging the o2 sensor, causing it to go into an “open loop” state. A CEL would likely come on, an there would likely be a loss of power, but if the “hunting/surging” also disappeared, that could be a good indicator that it is indeed a faulty O2 sensor. Does that sound right, or am I understanding that concept correctly?
08-18-2022, 05:34 PM
Real Name: Patrick
Real Name: Patrick
Denso #234-9002
That's the correct part number, but amazon and ebay are full of knockoffs so it could be a bad sensor. Do you still have the old sensor?
08-18-2022, 05:39 PM
I do, suspect you’re gonna suggest tossing it on to see what happens
08-20-2022, 12:22 AM
I said that because I had pulsating RPM's when in closed loop (You'll see that you don't have pulsation in WOT) and my problem was my first O2 sensor, without a check engine. And that first o2 sensor is an air fuel ratio sensor. got it from Rock Auto not from amazon, it's too risky.
1998 4runner SR5
08-20-2022, 09:52 AM
Real Name: Jon
Real Name: Jon
Good to know you seen this pulsing before. I always pull my o2 sensors from Rock Auto. Always had great success.
