Old 02-12-2023, 12:56 PM #16
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Originally Posted by JoeT4R View Post
Found a pair of used LC80 springs for sale. $40 in Cali, not sure if the seller would want to ship or not. But here's the link. I'm not associated with the seller in any way, just wanted to pass along some info.
FS - LC 8 wrap coil for 3rd gen rear $40 OC, California
Sent from my SM-T220 using Tapatalk
Thanks Joe! I've been thinking about a diff drop actually, but we'll see when the time comes.
Those LC's look promising, but I'd have to see if they'd work. Some say that they give up to or more than 3" of lift, which might be problematic for me with no current weight in the back
Edit: as I was writing this Zhehan posted that they'd be a bit too much, so I guess not
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 02-12-2023, 02:42 PM #17
Iron duke's Avatar
Iron duke Iron duke is offline
Iron duke has a spectacular aura about Iron duke has a spectacular aura about
Iron duke's Avatar
Originally Posted by RodrickHeffley View Post
It's been a year, which means that I'm looking at getting a lift again for this spring and summer!
I've already gotten a pair of RCD adjustable 5100s for the front with some TRD Tundra coils, but now I'm trying to figure out the back setup. I'd like to go with 2.5-3 inches of lift, which I believe the TRDs will give me in the front, but now I'd like some input on what to do next. I am going to get 5100s in the rear, but the coil question is the main thing here.
I've seen a few FB posts in my area of people selling different rear coils, so I'm interested in those.
There's one guy selling OME 891s, which I've read give 2-3 inches of lift WITH 150lbs in the back for less than new.
@Iron duke is also selling some extended travel 5100s which I'm tempted to get, but would that be too much?
OR am I better off just getting a set of 890s with the normal 5100s? Looking for some ideas or better options
If you want new suspension, get the best one with the money you have. I'm really not a big fan of my Billy setup. The digressive valving is not great for what I do, and I like a soft cloudlike ride. This is why I'm either going to rebuild and revalve a set of Icons, my buddy is selling me or go to Fox with the progressive valving. That being said, my setups will give you about 2-2.5" lift up front and about 3" lift in the back. It's really good if you ever want to get a drawer system, or fabricated rear bumper.
Iron duke is offline   Reply With QuoteReply With Quote
Old 02-12-2023, 02:45 PM #18
I was thinking that, I know I commented on there saying I didn't have enough money, but I got my paycheck the day after lol
I might get your extended 5100s, but I might need a few days to think
Would the extended 5100s and 890s be a good pairing with my 5100s/TRDs in the front?
281k Miles
Build Thread
Old 02-12-2023, 03:07 PM #19
Iron duke's Avatar
Iron duke's Avatar
I'd go with regular 5100's if you only want to go with the 890's. The extended ones will require extending the bumpstops, which will decrease your downtravel. That is not something you want to do with only ~2.5" lift
Old 02-16-2023, 12:24 AM #20
I found the 890s on amazon and want to get the 5100s there too so I don't have to pay for shipping or anything.
Are these the correct 5100s?
Amazon.com: Bilstein 5100 Monotube Gas Shocks Rear Pair for 1996-2002 Toyota 4Runner 4WD : Automotive
281k Miles
Build Thread
Old 02-16-2023, 11:39 AM #21
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Yep. Those are the correct shocks for that application.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 02-19-2023, 09:16 AM #22
djdaves djdaves is offline
Real Name: Dave
djdaves is on a distinguished road
Real Name: Dave
speaking from a budget stand point. for my setup i have the 890s and 5100s. Front setup was 5100 on 2nd perch with stock springs.
I did the diff drop and also replaced Lower Balls Joints to be save. All that new stress on old parts didn't sit well with me.
I'm happy with my choices. Then again i'm not a weekend overlander. I just wanted something other than stock appearance.
djdaves is offline   Reply With QuoteReply With Quote
Old 02-21-2023, 08:42 PM #23
beklemmung's Avatar
beklemmung beklemmung is offline
Real Name: Levi
beklemmung is on a distinguished road
beklemmung's Avatar
Real Name: Levi
Hijacking a semi-recent semi-relevant thread with a noob question of my own (1997 4x4 SR5). I'm in the process of replacing my worn out stock suspension with 5100s front and back, with 906 coils in the back and reusing my stock 4x4 springs up front. I bought a pair of new front strut mounts from Wheeler's. The description for the front 5100s says to also buy this set of new stem washers and cushions, but when I look at the Application Data for them, it says 1998+ 4Runner. Are these what I need, or do I need something else? I plan to have a shop assemble the coilovers for me as I don't want to mess with that myself.
Thanks in advance for the help.
1997 3.4L 4WD auto SR5, nearly 200k miles, pretty much all stock
beklemmung is offline   Reply With QuoteReply With Quote
4runner , back , lift , questions , shocks
Noob Lift Questions mistat313 4th Gen T4Rs 6 11-23-2014 02:40 PM
4th gen noob questions Brutalguyracing 4th Gen T4Rs 1 02-02-2014 07:45 PM
Noob 4x4 questions SilentYoda3 Classic T4Rs 9 05-13-2012 11:25 AM
Intro And Noob Lift Questions ClimbOrDie 3rd gen T4Rs 7 10-13-2011 12:39 PM
Noob with Questions - Looking to BUY rmd0311 4th Gen T4Rs 4 10-11-2006 12:32 AM
