Old 06-01-2022, 08:12 AM #1
gebomartin gebomartin is offline
gebomartin is on a distinguished road
Soapy Car Wash Water Coming Through Passenger Vent
Going through the care wash and half way through, the soapy car wash suds were coming out the passenger side dash vent. Got home and removed glove box and squirted water every where to try and duplicate it. No dice. I had noticed water would sometimes drip on my feet as I went through the car wash. I removed the driver and passenger side mats and they were damp underneath.
Where do I start?
2002 4Runner SR5 265K
gebomartin is offline   Reply With QuoteReply With Quote
Old 06-01-2022, 09:12 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Where do I start?
Dry everything out then have someone spray the windshield/roof area with a garden hose while you look for the leak inside the vehicle.
Old 06-01-2022, 09:30 AM #3
I did but found nothing. I will try again. Only soap suds come through the vent.
Old 06-01-2022, 09:36 AM #4
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 will become famous soon enough Malcolm99 will become famous soon enough
Malcolm99's Avatar
Highly likely it is coming from the windshield wiper cowl, there is a large hole there that leads directly to the blower motor and the passenger side vent is the direct path out. I've had to put a roof over these in tacoma's to stop the water from entering the blower motor.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 06-01-2022, 09:55 AM #5
Here is where the soapy water is coming from.
Soapy Car Wash Water Coming Through Passenger Vent-img_6003-jpg
Old 06-01-2022, 10:00 AM #6
Another pic showing the soap coming through that white tube.
Soapy Car Wash Water Coming Through Passenger Vent-img_5999-1-jpg
Old 06-17-2022, 02:26 PM #7
trevlf trevlf is offline
trevlf is on a distinguished road
Do you have a sunroof? If so check the sunroof drains. Blast some compressed air down the drain tube then run a garden hose and see if it drains to the ground. If you don't have a sunroof then I'm not sure how to help.
trevlf is offline   Reply With QuoteReply With Quote
Old 06-17-2022, 02:49 PM #8
Sunroof drains are fine.
Old 06-17-2022, 02:54 PM #9
Where exactly is that opening. I took the wipers and cowl off and ran volumes of water and both sides drained water behind the front door hinge area. It looks fine. I need to find the fresh sir inlet hole.
Old 06-17-2022, 04:24 PM #10
nissanh nissanh is offline
Soapy water makes form and will rise above the fresh air intake located below the wiper cowl. Those are now been pulled in by the fan and sent all over the duck lines. Next time when you go for a car wash, have the interior circulation mode on.
Your car has no problem.
The cowl is the plastic panel mounted horizontal below the wiper arms and between windshield and hood. The fresh air intake is located under the cowl towards the passenger side right above the blower motor. It is a raised opening so if you want to see it, remove the cowl, then flash a light from the driver side towards the passenger side.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 06-17-2022, 07:01 PM #11
I removed the cowl and wipers. I see the trough running from the passenger side to the drivers side. Where you are talking about is under that raised portion on the passenger side. Itís like a box/tunnel that is covering the trough. I canít see in it but what you say makes sense.
Thanks!
Old 06-17-2022, 08:06 PM #12
Inside that tunnel, you should see a raised rectangular/square metal opening. This is one of the famous mouse nesting ground when vehicle is parked for a prolonged periods. When fresh air door is open, debris will fall into the blower motor!
Old 06-17-2022, 10:29 PM #13
That makes sense. The suds are higher than the water so they run in and down into the blower motor. I understand. I want to thank you as you are the first person on any forum to explain this to me. Thanks!
car , passenger , soapy , wash , water
Water build up in my passenger side floor and behind passenger seat a4runner97 3rd gen T4Rs 12 03-23-2013 01:48 PM
Best way to prevent water spots after car wash 2Dragons Maintenance/Detailing 18 06-09-2011 12:26 PM
94 runner water coming from under dash on passenger side ivbutch Problems & Warranty Issues 1 06-16-2010 02:12 AM
Water in engine? Car wash accident miltapher Classic T4Rs 13 09-21-2009 12:50 PM
Vent Visors and High pressure car wash jminz 3rd gen T4Rs 7 02-10-2007 01:38 AM
