Originally Posted by PlutosT4r
You should be afraid of someone else breaking something. I'm learning that if you want something done right, you have to do it yourself. Have faith in yourself. The 20 year old at valvoline does not care about your truck as much as you do. Relevant to your OP, I remember first tackling my oil change because the shop wouldn't use the synthetic oil I researched and brought in.
Unless you overtorque the drain plug. It does help to have a friend there for the first time that's done it before or at the very least a click-type torque wrench with the drain plug spec (assuming the last person didn't already strip the threads).
