Old 06-04-2022, 07:47 PM #1
jimmyrecluse jimmyrecluse is offline
jimmyrecluse is on a distinguished road
Trans replacement and parts I'm swapping on the way
I ended up going with a Jasper reman transmission
It was about the same cost as the local rebuild but comes with an extra year and nearly unlimited mileage warranty
So I'm replacing the rear main seal, while I have it off
What else should I replace while it's apart?
I'm also replacing all of the major AC components. Evaporator core, condenser, compressor, expansion valve, drier, all of the hose seals
I'm rolling the timing belt and water pump into the same job.
jimmyrecluse is offline   Reply With QuoteReply With Quote
Old 06-04-2022, 08:14 PM #2
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
214RUNNER's Avatar
Flush clean the trans lines and cooler if the fluid was very dirty you might want to do it a few times.
214RUNNER is offline   Reply With QuoteReply With Quote
Old 06-04-2022, 08:19 PM #3
The last few changes, the fluid was clean because I did it on time. I also installed an external transmission cooler cooler maybe a year and a 1/2 ago.
I will definitely flush the cooler, or, either way.
Old 06-04-2022, 08:51 PM #4
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Maybe redo the oil pan sealant. Are all your internal seals good on your transfer? You can always get to the external output seals with it all back together.
When you do your valve covers if your engine is 250k or more. You may with to check your valve clearances. Probably a later project.
brillo_76 is online now   Reply With QuoteReply With Quote
components , major , replace , replacing , trans
Auto Trans Shifter Bushing Replacement & Transfer Case Shifter Seat Replacement mtbtim 3rd gen T4Rs 17 09-14-2022 08:23 PM
Trans Replacement - CA vs Fed Emissions Snacks99 3rd gen T4Rs 20 02-25-2022 04:31 PM
Auto Trans output shaft replacement? RHeld24 3rd gen T4Rs 4 08-03-2021 02:55 PM
Radiator replacement after trans cooler install browebb General Discussions 3 10-13-2015 05:15 PM
Parts swapping '06 to '03 dittodog 4th Gen T4Rs 1 06-11-2009 12:57 PM
