Old 06-07-2022, 06:21 PM #1
jimmyrecluse jimmyrecluse is offline
jimmyrecluse is on a distinguished road
Correct part numbers for the input and output shaft seals, 99SR5 4 wheel drive
I'm replacing the transmission and I'm looking for the input and output shaft seal part numbers. I'm having issues finding accurate information
jimmyrecluse is offline   Reply With QuoteReply With Quote
Old 06-07-2022, 08:42 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
For the transfer case or transmission?
Old 06-07-2022, 11:36 PM #3
I'm thinking both while I have the transmission out
Old 06-08-2022, 10:58 AM #4
Real Name: Patrick
Real Name: Patrick
What transmission do you have?
Old 06-08-2022, 01:30 PM #5
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Following
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 12:25 AM #6
Originally Posted by bad luck View Post
what transmission do you have?
a430 Auto
Old 06-09-2022, 10:01 AM #7
Real Name: Patrick
Real Name: Patrick
a430 Auto
Transmission pump seal 90311-38020
Transmission output seal 90311-40007
Transfer case input seal 90311-40021
Transfer case front output seal 90311-41012
Transfer case rear output seal 90311-41020
Transfer case shifter oil deflector (comes with 1 gasket) 36108-35060
Transfer case oil deflector gasket (2 gaskets required total) 36345-35050
input , numbers , output , part , shaft
Replacing Transfer Case Output Shaft Oil Seals, a How-To for DIY'ers BigFishAllDay 3rd gen T4Rs 82 06-21-2023 09:37 PM
5th gen tranny input/output shaft speed sensor Chrisjamo 5th gen T4Rs 3 11-08-2021 10:32 PM
correct part numbers for energy suspension sway bar bushings 2k1 3rd gen T4Rs 5 03-04-2014 02:13 PM
Is this the correct grease for drive shaft? msanta Problems & Warranty Issues 15 02-15-2005 11:51 AM
