Old 06-08-2022, 03:00 PM #31
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Major brake failure
So after a few more bleeds and troubleshooting I finally gave in and adjusted the rear brakes even more. The one side was already dragging so I adjusted it a bit more and then adjusted the other side to what felt like roughly similar and there you go. Completely fixed. No idea why the master swap fixed it. Hardest problems always turn out to be the simplest solutions I guess. I’m going to replace both wheel cylinders and redo the brakes in the back just to be safe even though they adjusted ok.
I don’t understand why that fixed it because both rear brakes were dragging already but I’ll take what I can get
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 06-08-2022, 05:09 PM #32
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
When you rebuild your rear brakes I found it helpful to use the parking brake a couple times once I thought I had the shoes adjusted correctly just to make sure the shoes were evenly centered and not off to one side causing premature drag on one side and a large gap on the other. While I'm thinking of it, you have 1 inch wheel cylinders since you have a Limited. I ordered the 15/16 inch ones originally when I rebuilt my old runner's rear brakes.
Old 06-08-2022, 05:33 PM #33
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Great news OP. Bleeding and rear adjustment got it fixed.
Old 06-08-2022, 05:45 PM #34
Real Name: Rich
Real Name: Rich
Still not sure how the rear brakes could have done all that. One drum took a hammer and pry bar to come off. The other side wasn’t as tight but was still dragging. I don’t see how that could have possibly been an issue. My girlfriends father is a Mercedes master tech of 25 years. He took one look at the back and he even said they were adjusted properly so I’m left scratching my head at this one. But alls well that ends well I guess
Old 06-08-2022, 09:49 PM #35
PlutosT4r PlutosT4r is offline
PlutosT4r is on a distinguished road
Hard to tell, a lot of extra details in the OP, but I think you may have had brake fatigue from limited rear braking. You learned this by now, but the drums are hard to get off no matter how little they're adjusted.
If it happens again in a few hundred miles, could be an adjustment issue --> frozen bell crank, parking brake malfunction, siezed or broken cable pivot. Maybe some other broken stuff in there. I haven't heard anyone reporting a stuck piston on drum brakes, but who knows, that could happen. You said yours only moved 1/8 of an inch, but we need context.
PlutosT4r is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 12:25 PM #36
3bears 3bears is online now
Real Name: 3 Bears
Real Name: 3 Bears
well glad you got it,
if your gonna replace wheel cylinders, get the bigger ones...dont know if it makes much difference... Supposedly there was a 15/16 bore and a 1 inch bore. When I did mine I made sure to order the 1 inch bore
3bears is online now   Reply With QuoteReply With Quote
Old 06-09-2022, 05:08 PM #37
Real Name: Rich
Real Name: Rich
What I’m still trying to understand is why didn’t the front brakes take up the slack from the rear? I don’t really have much knowledge on braking systems but I don’t get how one shoe slightly out of adjustment could cause the front 2 calipers both of which have new pads and rotors to basically produce no braking power. I understand that they were fatigued but the tundra front brakes should be more than enough to stop the car by themselves IMO. Am I wrong in assuming this?
Old 06-09-2022, 05:58 PM #38
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
No or little rear brakes overheats the front ones, any brakes that are too hot by design loose lots of braking ability, that is why your big ol' tundra fronts are not of much value alone.
Old 06-10-2022, 09:05 AM #39
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Maybe I missed it. Which size of tundra calipers did you go with? I think you had a combination of things going on.
1] air in the brake lines somewhere
2] the rear breaks don't take much movement to effect pedal travel. So one adjusted good and the other bad would effect the pedal height.
3] The tundra calipers come in 2 sizes. The wide 199mm size and the larger 231 mm size. The 199 mm is the same diameter rotor as stock. Just accepts a lot wider rotor and stock rims fit.
The 231 mm caliper is larger and the stock rims don't fit. Lots of members have reported soft brake pedal after doing this upgrade because the there is a difference in the caliper itself besides being wider.
4] it's best to get your emergency brake cable and bell cranks in good working order as you can use your emergency brake cable to keep your rear brake shoes well adjusted.
brake , brakes , floor , fluid , pretty
brake failure olalekanbabs 4th Gen T4Rs 52 04-07-2018 05:27 PM
Brake Failure - Pad is Gone WRM1 5th gen T4Rs 21 07-06-2016 01:13 PM
Help. Major Brake issue <<<< 4th Gen T4Rs 2 02-19-2016 11:42 PM
Major brake issues, prob simple just to blind to see it Ekimrm Classic T4Rs 15 02-28-2012 12:23 PM
Brake Failure 4runnerLVR Problems & Warranty Issues 2 07-11-2005 10:16 AM
