Old 06-24-2022, 01:04 PM #61
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by Bad Luck View Post
That's what my moog inner tie rod boots came with
Well to be honest it was more like WTF using sevaral $.02 parts to protect a $200 investment in what looks to be a harsh environ.
Old 06-27-2022, 09:47 PM #62
Colorado buff Colorado buff is offline
Colorado buff will become famous soon enough
What does the metal locking tab look like?
Colorado buff is offline   Reply With QuoteReply With Quote
Old 06-27-2022, 10:06 PM #63
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Something similar to this instead of the zip tie: https://www.amazon.com/dp/B000COCQ0Q...YVN5GQDTEPTQ_0
Zip tie will work fine though
Bad Luck is online now   Reply With QuoteReply With Quote
Old 06-27-2022, 11:14 PM #64
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Honestly I'd prefer a zip tie over those stupid ass bands Toyota put on... Gonna work just as well but be 100x easier to take off in the future
Though how much you'll actually be taking them on and off is certainly (/hopefully) minimal, but still.
Old 07-01-2022, 09:37 AM #65
Grazie!
Old 01-21-2024, 05:25 PM #66
TristanSnively TristanSnively is offline
TristanSnively is on a distinguished road
Originally Posted by sportscarfan View Post
These still seem like a decent deal to me - OEM Toyota parts, but shipped from Japan. They were $191 shipped when I bought a year ago.
It's both LBJ's + bolts.
Toyota 4Runner Lower Ball Joint LH RH set NEW Genuine OEM Parts | eBay
If you want to shop, the Left/Right part numbers are 43330-39585, 43340-39465.
Just curious how are these holding up? Does the quality really seem oem? I've been looking for oem LBJ but they've all gone up and are in like 250+ range if these are legit thatd be great
TristanSnively is offline   Reply With QuoteReply With Quote
Old 01-22-2024, 06:25 PM #67
StangRunner StangRunner is offline
StangRunner is on a distinguished road
Hi All, just wanted to share my experience with OEM LBJ from my local dealer... I just had to replace my 2yr old sub-20k miles ball joints due to noticeable play on both sides. My originals had zero play at 160k miles but I decided to replace them as 'preventive maintence' (should have left them alone lol). The only off-roading these saw were two trips to some sand dunes in Michigan, which were admittedly very abusive, and a ton of pot holes on our terrible Wisconsin roads. I was running 32" A/T's on stock 16" wheels for the majority of the miles and 31" snow tires on 17" 5th gen wheels for the last 500 or so miles with stock ride height (99 tall springs) prior to noticing the play. Even still at nearly $300 for the set, I'd expect better.
I'm curious if anybody else has had similar experiences as it really seems that the QC standards have lapsed since these vehicles were new. Here is a link to a video I took of the play. It was the same on both sides.
iCloud Drive - Apple iCloud
I'm wondering if there is any possibility, with enough people complaining, of Toyota investigating this issue and possibly work on a solution since a failure can be potentially deadly, especially since there really aren't any noticeable noises prior to them failing and one shouldn't expect a failure having changed them so recently. The majority of people think 'my originals lasted 20 years, the OEM replacements should last just as long' which is absolutely valid but based on my experience, not the case. I see all this talk of re-greasing but my engineer mind makes me think that this is a heat treat / material hardness, and fatigue issue.
Its obvious that the design is inherently flawed, with the LBJ being in constant tension, but it is clear that the design was optimized to the best of their abilities when new since there likely was not a single failure of original LBJ's prior to 150k miles. Working in automotive component design, I've learned that there are certain criteria that have to be absolutely perfect if you want something to last and I'd bet my life that any aftermarket manufacturer does not have or is not willing to invest the money in optimizing materials when making a part like this.
The closest I've seen to a true upgrade or fix are the heim conversions from Total Chaos but I for one do not want and shouldn't have to spend $1000 on a part that should not be a problem to begin with. It might be a good choice for people with extra deep pockets not living in the rust belt but those will turn to absolute crap in a year or two where I live.
Toyota 4Runner 1996-2002 3RD GEN 4RUNNER LOWER UNIBALL CONVERSION - TC HEIM STEERING | TOTAL CHAOS FABRICATION
Thanks,
Sam
StangRunner is offline   Reply With QuoteReply With Quote
Old 01-22-2024, 08:11 PM #68
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Thanks,
Sam
Anonymous Fabrications offers the same thing for much cheaper. He uses a 7/8 uniball instead of 1", which is still plenty strong and half the price to rebuild - and also uses the factory castings so you can retain normal steering (you can also send in a spare set of LBJs for even more money off). Me and a few other users have been running them for a while now and they're working great. I'm assuming others would agree because he's expanded his selection to Tundras and Sequoias too, and those were frequently sold out for a while. He used to be a user on here and actually created and sold them first, beat Total Chaos by about a year. Really nice guy
AF also offers a boot kit for them to give a little protection from dust and water too, and I myself found a boot solution as well. No squeaks or anything after a couple years, haven't rebuilt either of them
Old 01-22-2024, 09:32 PM #69
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
There is a snowballs chance in hell that toyota will do anything about a minimum 22 year old vehicle design and fix anything to do with its parts.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 01-22-2024, 11:43 PM #70
That's awesome... I had not heard of those. Gonna have to hit him up. Thanks for the share.
Old 01-23-2024, 11:40 AM #71
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
+1 for Anonymous Fab. I am running his uniballs and they are great.
JZiggy is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 11:43 AM #72
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
I'd love to get those as well, but they are out of stock, it appears.
ETA - Josh just told me that they are revamping their uniballs to accept a 1" ball.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 12:42 PM #73
Real Name: Patrick
Real Name: Patrick
I second this motion. Vehicle is well out of any warranty or liability to the manufacturer.
Old 01-23-2024, 01:58 PM #74
I agree to a point, but if they sell a defective part and it causes an accident, they can 100% be held liable for damages. I work for an OE automotive supplier and we continue to support service parts for vehicles that are well out of warranty and will totally get burned if a service part with the customer's name on it causes damages. Granted, it would take a class action lawsuit to get anything changed but its not outside the realm of possibility. Wishful thinking I suppose...
Old 01-23-2024, 04:03 PM #75
Real Name: Patrick
Real Name: Patrick
A design flaw and a defective part are two entirely different aspects for Toyota. I'm not sure how Toyota handles it, but for GM if the part was not installed by a GM dealership then there's no liability attached to that part. There is no way for anyone to prove in a court beyond a reasonable doubt that the part was installed correctly following the correct procedure and using any applicable torque values.
ball , joints , lower , oem , question
Lower ball joint/Spindle hub failure TravThePro 3rd gen T4Rs 4 07-21-2020 12:40 PM
Lower Ball Joint Torque and Failure Question jmansfield 3rd gen T4Rs 13 07-15-2020 09:30 AM
New Twist on Lower Ball Joint failure Pikeman 3rd gen T4Rs 105 05-20-2018 05:01 AM
Lower ball joint failure??? RogueOne 3rd gen T4Rs 18 01-27-2015 05:56 PM
Lower Ball Joint Failure Questions BlindShepherd 3rd gen T4Rs 23 09-01-2012 09:03 AM
