Old 06-08-2022, 03:58 PM #1
Colorado buff Colorado buff is offline
Colorado buff will become famous soon enough
Lower Ball Joint Failure questions
Hey All,
I was driving home and luckily at low speeds and was making a left turn when my right lower ball joint failed.
I replaced these with OEM joints 50,000 KM ago.
My first question is how long do OEM lower ball joints last?
Second Question, roughly what should I be spending at a mechanic to repair right and left LBJ?
any commentary would be great. Trying to attach photos but attachment doesnt seem to work.
Colorado buff is offline   Reply With QuoteReply With Quote
Old 06-08-2022, 04:30 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
50k is short, most think that 100k Miles is a very conservative time to replace, and 200k Miles is more normal (with actual life well past that). That's assuming you're at Stock ride height... lifts and bigger tires both reduce this number. Similarly, hardcore wheeling will also shorten life.
Curious, was the actual ball joint that failed or the BOLTS that hold the balljoint that failed? Lots of mechanics/people will re-use the bolts and those have been noted as a failure prone area. Mostly OEM Toyota LBJ's have been well documented to last Way longer than aftermarkets... some have killed aftermarkets in 10k miles, but they were lifted and wheeling.
Sorry it happened, glad it's pretty much limited to slow speed situations (tight turns) in general and hope there's not really any other damage you need to repair. Make sure to do both sides, not just the failed side... unless you're itching for a repeat in a month. And cost will be highly variable depending on location and number of mechanics in the area, this is an easy DIY job... probably $250 in parts and ~$300 in labor (USD, not sure where CAD is right now).
Note there IS a "kit" part number for both L and R, I think it's minus the bolts, but saves you about 10% over buying separate.
Brian. is offline   Reply With QuoteReply With Quote
Old 06-08-2022, 05:01 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
100K miles/10 years for stock vehicles that see up to mild trail use is generally recommended. Hopefully you can post some pictures of the failure point
Old 06-08-2022, 05:58 PM #4
Thanks all! Will try and post again
Old 06-08-2022, 07:41 PM #5
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
These still seem like a decent deal to me - OEM Toyota parts, but shipped from Japan. They were $191 shipped when I bought a year ago.
It's both LBJ's + bolts.
Toyota 4Runner Lower Ball Joint LH RH set NEW Genuine OEM Parts | eBay
If you want to shop, the Left/Right part numbers are 43330-39585, 43340-39465.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 06-08-2022, 07:51 PM #6
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Here is a basic way to upload pix into your comment from a computer.
Click on the Paperclip icon, Browse to the file on your device, click Upload.
I have noticed that in some cases an image with a larger than about a 1400 pixel dimension in L or W will 'Fail' to upload. Sorry for the crappy graphic below.
Lower Ball Joint Failure questions-uploadz-png
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 06-08-2022, 08:06 PM #7
Bless and thanks
Old 06-08-2022, 08:07 PM #8
Thanks maybe my images are too large will shrink them and try again.
Old 06-08-2022, 08:13 PM #9
here are some photos
Old 06-08-2022, 08:15 PM #10
take two. Here are some photos. Thanks my images were too large
Lower Ball Joint Failure questions-img_8539-jpg  Lower Ball Joint Failure questions-img_8540-jpg  Lower Ball Joint Failure questions-img_8541-jpg  Lower Ball Joint Failure questions-img_8542-jpg
Old 06-08-2022, 08:22 PM #11
question: I put on bilstein 5100's and new coils so the truck does ride a little higher. Would this count towards your lift lowering the useful life of LBJ's? or were you speaking towards the people here that add spacers and all the extras?
Old 06-08-2022, 08:47 PM #12
Brian.'s Avatar
Brian.'s Avatar
That's all kinda variable... looks like you have a pre-facelift (1995~1998), so what little change you encountered probably got the vehicle to about the stock height of the 1999's (tallest of the bunch). It's been a few years since I did the research, but I think it was 3"+ lifts for most (or about 2" on the 1999's, which I have).
Your Bils 5100 weren't the most likely cause.
I'm still thinking it was bolts with a possibility of counterfeit LBJ (unless you bought them at the dealer).
Old 06-09-2022, 09:03 AM #13
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
There's not a great clear shot, but it does look like the ball pulled out of the socket, so not an issue with either under or over torquing the 4 smaller bolts, or the one large nut.
There's really no way a good OEM balljoint should fail in 50000k (around 30K miles) unless it was damaged in some way. Either thumped hard which accelerated wear, or the boot was torn (either during installation or shortly after) and it got rusty/contaminated inside.
Maybe it was a defective part? I have a 3" lift and 33" tires on mine, and wheel it fairly hard with some regularity, and I still stick to a roughly 75- 100K mile replacement routine, but I also keep an eye on the grease seals and bolts every couple of months. And if the boot is torn or leaking grease for any reason, I'll just go ahead and replace it.
JohnMc is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 09:07 AM #14
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough Cree will become famous soon enough
Cree's Avatar
You can clearly see the joint separated. Looks like it was likely a faulty joint. However, OP I have to ask, Did you check to make sure these were greased before you installed them?
00 Limited - Stuff!
18 Audi A6 3.0T - APR Tuned, RS6 Interior
19 Audi A6 3.0T
Cree is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 12:48 PM #15
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I think there was a case here a while ago where the OP peeled back a ~5k mile OEM ball joint boot and discovered scratches on the joint. Ruled as defective so the parts were replaced. Wonder if this could be the cause as to why yours failed. Seems like OEM ball joints aren't made like the factory ones 20+ years ago.
2000 4Runner Limited 4x4 V6
ball , joints , lower , oem , question
Lower ball joint/Spindle hub failure TravThePro 3rd gen T4Rs 4 07-21-2020 12:40 PM
Lower Ball Joint Torque and Failure Question jmansfield 3rd gen T4Rs 13 07-15-2020 09:30 AM
New Twist on Lower Ball Joint failure Pikeman 3rd gen T4Rs 105 05-20-2018 05:01 AM
Lower ball joint failure??? RogueOne 3rd gen T4Rs 18 01-27-2015 05:56 PM
Lower Ball Joint Failure Questions BlindShepherd 3rd gen T4Rs 23 09-01-2012 09:03 AM
