Old 06-10-2022, 11:19 AM #1
Calloway Calloway is offline
Calloway is on a distinguished road
Wheel question?
So my buddy just picked up a 2022 Ford Bronco. He's changing the wheels and tires and asked if I wanted them.
Will 2022 Ford Bronco wheels for on a 2000 Toyota 4 Runner?
They have the same lug pattern size 6 x 139.7. But not sure about the bore size.
TIA!
Calloway is offline   Reply With QuoteReply With Quote
Old 06-10-2022, 11:47 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
TIA!
Did you try asking google? 2022 FORD BRONCO WHEEL BORE - Google Search The very first link will have your answer.
Old 06-10-2022, 11:53 AM #3
Thanks Bad Luck. Sorry I did Google and pulled up this website as well. So the bore size is different 93.1mm (Bronco) vs 106.1mm (4Runner).
I just wasnt't sure if I could still fit these on with adapters or if it was a complete no go.
Old 06-10-2022, 12:09 PM #4
Real Name: Patrick
Real Name: Patrick
Anything is possible with adapters, but to do it correctly would require hub centric wheel adapters to change the bore size down and retain hub centric alignment. Hub centric adapters are pricey and you would need all 4. The adapter spacing and bronco wheel backspacing/width might cause rubbing and other fitment issues. That juice isn't worth the squeeze in my opinion.
EDIT: Hub centric adapters have a female bore for the 4Runner and a male lip for the bronco wheel bore.
Old 06-05-2024, 03:12 PM #5
meatbillfold meatbillfold is offline
meatbillfold is on a distinguished road
Unfortunately the center bore on the Bronco wheels are too small. We require 106mm (.1 or .2 if memory serves).
meatbillfold is offline   Reply With QuoteReply With Quote
Old 06-06-2024, 01:36 PM #6
Same/similar issue with most 6-lug Chevy wheels...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
bronco , ford , size , wheel , wheels
2015 TRD Pro wheel VS 2015 Trail wheel question Hybryd40 5th gen T4Rs 53 08-12-2017 12:57 AM
Wheel and Fitment wheel and tire question (another one... I suck, I know) swapmeet 4th Gen T4Rs 2 04-02-2015 04:09 PM
XD Wheel Question JMG73072 5th gen T4Rs 1 01-28-2013 05:05 PM
Wheel question?? RowdyTundra07 5th gen T4Rs 3 05-01-2010 11:37 PM
wheel question riceandpho 4th Gen T4Rs 1 04-13-2009 06:58 PM
