06-13-2022, 04:00 PM
Is this Camelback radiator OEM?
$122.80 seems psychotically low for an OEM radiator considering several aftermarket units are higher than that. I know Camelback has good pricing on parts but damn. Can anyone provide feedback before I pull the trigger? My rad is getting some hairline cracks and needs to be put out to pasture.
1996-2002 Toyota 4Runner Radiator Assembly 16410-AZ011 | Camelback Toyota Parts
'98 Desert Dune Limited (200K+)
06-13-2022, 05:20 PM
Real Name: Rich
Real Name: Rich
Originally Posted by PRG3K
That’s the same part # mine was when I got it. The factory rads are surprisingly cheap. I picked mine up from Lakeland Toyota for 140 bucks shipped. Some dealers will charge a lot more but that one seems legit to me, unfortunately the shipping charges are usually what brings the price up quite a bit
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
06-13-2022, 06:06 PM
umm... Camelback doesn't really have better than average pricing (more expensive than my local dealer 100% of the time), and their customer service was crap, a complete joke the one time I ordered.
16410AZ011 - Toyota Radiator assembly | LaGrange Toyota, La Grange GA
$113 before shipping from my local dealer. You should really check the dealers around you so you can do a local pickup. That way if it's damaged, you can refuse it at the counter... and damaged in shipping is extremely common.
16410AZ011 - Radiator assembly - Genuine Toyota Part
And this radiator, while "oem", isn't the same as what was installed originally. Those are no longer available and last sold in the $600 range.
Edit to add, you have to click on the "Shop Now" button for each and every dealer to see Their pricing.
06-13-2022, 06:07 PM
Real Name: N/A
Real Name: N/A
When I was purchasing parts for my exhaust manifold swap camelback came in over 100$ lower than my local dealership, even including the 10% discount I get at my local dealership.
Some people have had bad experiences with them, but I never have
So it's probably legit
1998 4runner 2.7 manual
06-13-2022, 07:35 PM
Real Name: C8H18 Mike
I paid $117 from my local dealer
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
06-13-2022, 08:11 PM
Real Name: Mark KN6TZI
Currently $114/$118 at two local dealerships here.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
06-13-2022, 10:04 PM
Yeah I get that. I think it largely depends on the part. Camelback was way higher than McGeorge and other places when I was pricing out an OEM suspension rebuild, but they have lower prices on other stuff.
I think I was shocked because I saw a quote for 5-600 bucks for the first OEM one I looked at but it must've been one of the original Japanese-made units or something. Thanks for the feedback guys.
06-13-2022, 10:47 PM
The dealer radiator is a good part. Buy with confidence. They’re cheap in the grand scheme. Cost less than 2 tanks of gas now. No reason to not replace them.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
06-14-2022, 01:01 AM
My "OEM" radiator came in a Lexus box and has a Denso sticker on the top. Looks every bit the quality part as the original, and yes, buy from your local Toyota parts counter guys. Unbox it on the spot and check for damage.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
06-14-2022, 01:25 AM
Originally Posted by TheSaturnV
...buy from your local Toyota parts counter guys. Unbox it on the spot and check for damage.
Parts counter prices are sky high. I buy from parts. localdealer.com and pick up at the parts counter.
06-14-2022, 03:39 PM
So update, they cancelled my order because "We regret to inform you that we no longer ship the following: Body parts, Batteries, Radiators, Fan Shrouds or hazmat items. At this time we can not fulfill your order. A full refund has been issued. We apologize for any inconvenience this may have caused. " Took your advice and just going to pick one up at my local dealer.
06-14-2022, 04:12 PM
They did the same to me. Call your local Yota dealer
06-14-2022, 04:39 PM
Me too on a fan shroud. Price was foolish anyways. Plastic welded the crack it had. New
06-15-2022, 03:54 PM
The made in Japan radiator is pn 1640075181 usually in the $365+ range . I was told by Toyota parts that their cheaper priced radiators from Taiwan (16410-YZZAJ, 16410-AZ011, Denso 221-0508) were offered to compete with other similarly priced aftermarket radiators.
Link to where I got my radiator 1640075181.
2002 Toyota 4Runner SR-5 4WD Radiator. Engine, Cooling, Make - 1640075181 | Cobb County Toyota, Kennesaw GA
Thread for 1640075181.
16400-75181 Radiator: Made in Japan
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
06-15-2022, 08:57 PM
If you replace the radiator every hundred thousand miles per FSM then it's origin shouldn't matter too much
I've got a Taiwanese Denso in my two wheel drive that's been in there for 20-30 thousand miles and it still looks brand new
