Old 06-14-2022, 02:37 PM #1
2wdguy 2wdguy is offline
Real Name: Ray
2wdguy is on a distinguished road
Real Name: Ray
Vacuum Hoses & Fuel Hoses Source
Im looking for a Vacuum Hoses & Fuel Hoses Source. It seem the sizes at autozone etc are too loose. The replacements from toyota are priced super high.
What are sizes used? Sources with links will be appreciated.
2wdguy is offline   Reply With QuoteReply With Quote
Old 06-14-2022, 03:08 PM #2
prcGTI's Avatar
prcGTI prcGTI is offline
Real Name: Jeff
prcGTI is on a distinguished road
prcGTI's Avatar
Real Name: Jeff
Vacuum hose kit option
Not sure about the fuel hoses but I've seen others reference using this silicone kit to completely refresh all of their vacuum hoses.
Silicone Boost/Vacuum Hose Engine Dress Up Kit, Black
Hope this helps your search
2001 4Runner SR5 4x4, V6 Auto, ME Silver|2nd Owner|5 Stars with 265/75/R16 Falken Wildpeak AT3Ws
4.88s w/ front and rear ARB lockers|Shrockworks front bumper, rear bumper with swing out, and rock sliders|Tundra TRD Pro springs and Bilstein 5100s|OME 890 springs and Bilstein 5100s|SS Fully Adjustable Trac/PanHard Bar|SS Diff drop|TBU – 13WL calipers w/ Stoptech slotted rotors|Prinsu full length roof rack|Smittybuilt X20 winch|ARB CKMA12 compressor
prcGTI is offline   Reply With QuoteReply With Quote
Old 06-14-2022, 03:14 PM #3
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
I just went through this. Some hoses can be replaced with generic hoses, and if you're on a budget, that's the way to go.
I tried doing that in a few spots, and it looked horrible. Most Toyota hoses are preformed, and generic hoses won't have that shape. And to make things worse, many of them are different diameters on the two ends.
I just ordered about 15 OEM hoses from Amayama. Some are dirt cheap (at least in my book), under $5 each. A couple were pushing $20 each, one was $40. I grimaced, then hit the "Buy" button - buy once cry once. Overall it was about $200-300 bucks - not chump change, but worth it (to me) to keep it looking good.
But I'm the wrong guy to ask if cost is an issue, I'm about to take a bunch of bolts and brackets to a plating shop to have replated.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 06-14-2022, 04:46 PM #4
firemanj92 firemanj92 is offline
firemanj92 is on a distinguished road
I ordered the silicone kit and then replaced everything with OEM for both our 3.4L v6s. The 3.5mm Toyota part #90999-92008 is approx 102" which was enough to replace all the small 3.5mm hose under the hood of 2 T4R's.
92006 = 51"
92007 = 64"
92004 = 37"
92003 = 23.5"
92002 = 12"
You can find it at any Toyo stealership, or yotashop.com, absolute-wits-end.com just to name a couple of reliable vendors and for metric ethanol fuel safe hose related hose try Belmetric.com
firemanj92 is offline   Reply With QuoteReply With Quote
Old 06-15-2022, 11:17 AM #5
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
92006 = 51"
92007 = 64"
92004 = 37"
92003 = 23.5"
92002 = 12"
This is the way to go. I bought one of these OEM bulk kits and the hose quality was excellent. Just pull off the hoses you want to replace one at a time, cut to length, and pop it on.
JZiggy is offline   Reply With QuoteReply With Quote
Old 06-16-2022, 02:17 PM #6
ST6Detailers ST6Detailers is offline
ST6Detailers is on a distinguished road
Amazon
ST6Detailers is offline   Reply With QuoteReply With Quote
Old 06-16-2022, 02:52 PM #7
maxthebird maxthebird is offline
maxthebird is on a distinguished road
Used the Silicone Boost/Vacuum Hose Engine Dress Up Kit mentioned above a couple of years ago to replace my rubber vacuum lines. No need to get the small preformed ones from Toyota as these have thick walls and are flexible enough to bend without constricting. Works great and still a nice glossy black. Highly recommended.
maxthebird is offline   Reply With QuoteReply With Quote
Old 06-16-2022, 09:49 PM #8
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Which size does the 4wd system use for the vacuum tubing? Mine is looking rough.
Do the silicone hoses handle engine oil well, my 4runner leaks a lot
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
fuel , hoses , sizes , source , vacuum
Vacuum hoses; need to replace. sakoluvr 3rd gen T4Rs 10 11-15-2021 11:43 PM
Help with vacuum hoses. JPwrangler Classic T4Rs 2 03-16-2014 10:29 AM
Vacuum hoses RussB Classic T4Rs 9 05-30-2012 12:27 PM
Vacuum hoses the_dingman Classic T4Rs 3 04-07-2010 12:18 AM
vacuum hoses jcapusmc 4th Gen T4Rs 3 06-01-2006 09:35 PM
