Old 06-24-2022, 08:47 PM #46
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by T4Rscott View Post
I went through the diag for the ac. Pin 3 to ground with clutch engaged was 5v
Is that what it supposed to be or is it supposed to be 12v? What does the book say it should be?
Old 06-25-2022, 01:22 PM #47
T4Rscott's Avatar
T4Rscott T4Rscott is offline
T4Rscott is on a distinguished road
T4Rscott's Avatar
All the book says is “positive battery voltage.”
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
T4Rscott is offline   Reply With QuoteReply With Quote
Old 06-25-2022, 02:19 PM #48
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Hmm. I have a 1997 limited my ac quit on. I have to figure out why ... was working great with new Condenser drier and fully charged for many weeks then nothing. Lol.
Old 06-25-2022, 03:37 PM #49
T4Rscott's Avatar
T4Rscott's Avatar
I know a guy who is close to me that buys these generation 4Runners and parts them out.
He gets pallets of west coast rear ends and other parts all the time.
If you need a compressor, hit me up. I have a good one cheap.
Old 06-25-2022, 05:17 PM #50
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My compressor should be good.. I look into it here i was working on the patches on Tetanus 1 hatch repair... :-)
Thanks for the information though.. I keep that in mind.
Old 06-25-2022, 05:19 PM #51
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Sorry for the delayed response, need to get an appendicitis today; so I'll try to get you diagrams and information late tonight or tomorrow depending on how I feel.
And battery voltage is roughly whatever your battery is currently at. i.e. if the vehicle is running it'll be in the 13-ish volt range and if the vehicle is not running it should be about 12.6 ish volts on a good battery, but in general they're looking for basically over 11.4v key on engine off at minimum with at least 12v being the ideal minimum.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-25-2022, 10:07 PM #52
T4Rscott's Avatar
T4Rscott's Avatar
So, the 5v seen with the amplifier plugged in engine at idle, max cool AC on is not ideal?
Old 06-25-2022, 11:42 PM #53
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Let's see battery voltage is 12 to 13 volts. You are measuring 5v. Provided your meter is set properly. Then the answer is no. It's not 12 to 13v
What does the manual say to do if it's not 12 to 13v. (Battery voltage)?
Old 06-26-2022, 12:07 AM #54
T4Rscott's Avatar
T4Rscott's Avatar
It basically says to try another amplifier
Old 06-26-2022, 02:59 PM #55
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well mine will be fixed here shortly. Bad pressure switch. I just Need the switch and it sucked out and put back in to repair my 97 limited. What the part number of the amplifier?
Old 06-27-2022, 02:58 PM #56
Alright sorry for the delay; apparently my appendix almost burst Saturday and I've been recovering from surgery.
Here's a '99 Manual A/C wiring diagram as promised; I'll have to go through it when my brain isn't fogged with meds and pain.
Old 06-27-2022, 03:12 PM #57
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Glad your doing better...But may want to rest a while longer as your link is messed up.. Well it wont let me open it. :-)
Old 06-27-2022, 03:41 PM #58
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
99 sr5
-download-1-png  -download-2-png
SaulG is offline   Reply With QuoteReply With Quote
Old 06-27-2022, 04:01 PM #59
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by SaulG View Post
99 sr5
Not working for me at all. Doesn't even have a hyperlink for me to click on for it.
Old 06-27-2022, 04:11 PM #60
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well you have to watch with tapatalk. As in iffy with pdf files. I was on my pc and the first one didn't work.
compressor , issue , i’m , pressure , system
I'm baffled - Thunk, clunk, pop! WTH WRfarmer 3rd gen T4Rs 6 07-30-2019 03:25 PM
Help! Lean has me baffled... kdub351 5th gen T4Rs 29 04-02-2019 02:19 PM
Feeling Baffled. WeldTightFab 4th Gen T4Rs 1 07-27-2015 11:05 AM
My Mechanic is Baffled scrbear11 4th Gen T4Rs 17 07-28-2013 11:12 PM
I'm baffled... 1995 4runner dwighter Classic T4Rs 1 02-07-2011 01:50 AM
