Not the ecu then left with wiring and bad amplifier. That entire thing is crazy.
You still have pressure and referent in the system?
As you could have a leak and the 134a gone.
I had one do that to me that I need a new ac line for. As my actual line itself is damaged leaking the refrigerate.
I never seen your issue before. Now I greatful to have to only deal with the leaks problems.
I knew I should have grabbed that ac amplifier out of that 1999 ...
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
