Old 07-04-2022, 09:25 PM #91
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Originally Posted by brillo_76 View Post
Hard to say the cause. I know they are dead in this thread. Are they dead across the entire forum or just this thread?
Seems to be just this thread (or subforum?) links in following thread work, for example Fog lights with high beams... the easy way
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 07-05-2022, 03:09 PM #92
T4Rscott's Avatar
T4Rscott T4Rscott is offline
T4Rscott is on a distinguished road
T4Rscott's Avatar
Do you do testing connected and not connected on the AC amplifier connection? Because if your sure you have the proper refrigerate amount. With your pressure switch working properly. Your down to a wire harness issue like the FSM says.
Yes I have. That’s how I got only 5v on pin3 to ground connected. I disconnected the harness from the amplifier to thermistor and back to the dash, no issues there. I’m going to do a continuity test from the different pins to the endpoints, like pressure switch, clutch and so on….
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
T4Rscott is offline   Reply With QuoteReply With Quote
Old 07-05-2022, 03:56 PM #93
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Edit: Had the wrong year 1997
This is 1999 So I deleted what I could @badluck and T4Rscott will have to delete their replies
Old 07-05-2022, 05:51 PM #94
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
1999 EWD of AC in photos [8]
Old 07-05-2022, 07:54 PM #95
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
I quickly glanced the thread, and I understand you don't have manifolds to check the pressures and what happens when you press the gas?
You going on blind if that is the case. There are cheap manifold sets on amazon that you could use for this time, might not last and might leak, but at the least you would see what's actually happening and not go blind. Impossible to diag A/C without manifolds
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 07-07-2022, 09:14 AM #96
T4Rscott's Avatar
T4Rscott's Avatar
When I step on the gas pedal the clutch engages, and when I let off, it will stop.
I understand what you are saying about the gauges. However, the pressure was fine at the time it was serviced and was still doing the same thing. I will look into a set from Harbor Freight.
Old 07-07-2022, 05:56 PM #97
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I would just verify with gauges.. As my limited AC wouldnt work at all. Thought all i just have a bad pressure switch because the PO had the ac disconnected and I figure the Switched just failed. So when I took it to my buddys to have it evacuated to replace the switch... I only had 10 pounds psi. My 1997 limited has a leak. Hopefully the dye in the system will so me where this leak is.. I changed the switch anyhow. Put a almost 2 cans of 12 oz refrigerate in and See if i can find my leak.
Yours could be perfect pressures. It will rule it out.
I think if your system is all checkes out and your amplifirer is good.. You have a wiring power issue somewhere ad that is all that is really left. :-(
I did finally get the electrical diagrams in photo form on this thread for the 1999 model year..
Old 07-08-2022, 05:08 PM #98
T4Rscott's Avatar
T4Rscott's Avatar
Ok, it’s the time you’ve all been waiting for, 😆
I put the gauges on it, and here’s the results:
With the engine @1500 rpm, AC on, fan on HIGH and temp at max cool,
Low side was 30-35 psi
High side was 350-400 psi
When the engine returned to idle:
Low was 80-85 psi
High was 200-225psi
The outside temp was about 85 and to was 45% humidity.
According to the FSM, it could be the condenser or the expansion valve.
Let me know what you all think.
Scott
Old 07-08-2022, 06:44 PM #99
azrex azrex is offline
azrex is on a distinguished road
Your high-side pressure at 1500rpm is way too high and the low side is a bit high. At idle, your low side should be roughly 30.
Possible causes: weak fan clutch or overcharged system or partially plugged condenser, which could be something internal or the fins plugged by dirt or mud.
A bad expansion valve usually results in the low side being very low or going into vacuum.
azrex is offline   Reply With QuoteReply With Quote
Old 07-08-2022, 07:03 PM #100
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ok.. how was this system refrigerate amount verified.
Was the system evacuated and the proper amount of refrigerate pushed in? Or are we just reading gauges psi and tweaking it this way?
Because the you pressure can be right on the edge where the safety switch it tripping out.
Plus what does your site glass looking like? As that glass can tell you alot how the ac is system.
Old 07-08-2022, 07:22 PM #101
T4Rscott's Avatar
T4Rscott's Avatar
I can only go by the shop that did the evac and refill. They used a Robin Air machine.
I looked at the condenser and it is rough. I remember when I did the radiator, the fins were popping out very easily due to age and corrosion.
Old 07-08-2022, 08:07 PM #102
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Those pressures at idle and 1500rpm lead me to believe your system is overcharged
Old 07-08-2022, 08:43 PM #103
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
And if it's overcharged it can blow the compressor [ yes I did that before ] You can't tell how much refregerate is in the system.
I blow a compressor using gauges. I had a bad Condenser and naturally way too much refrigerate. Blew the compressor and it was over. Pressure equal on high and low.
If your ac system. Wasn't evacuated and the proper amount of refrigerate put in. Then that's were you start.
Unless your tracing leaks like I am. You really have to watch the refrigerate amount.
Old 07-08-2022, 08:51 PM #104
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What the sight glass can tell you.
Old 07-09-2022, 11:35 AM #105
T4Rscott's Avatar
T4Rscott's Avatar
It was filled appropriately according to the sight glass.
compressor , issue , i’m , pressure , system
I'm baffled - Thunk, clunk, pop! WTH WRfarmer 3rd gen T4Rs 6 07-30-2019 03:25 PM
Help! Lean has me baffled... kdub351 5th gen T4Rs 29 04-02-2019 02:19 PM
Feeling Baffled. WeldTightFab 4th Gen T4Rs 1 07-27-2015 11:05 AM
My Mechanic is Baffled scrbear11 4th Gen T4Rs 17 07-28-2013 11:12 PM
I'm baffled... 1995 4runner dwighter Classic T4Rs 1 02-07-2011 01:50 AM
