Old 07-31-2022, 03:24 PM #121
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by T4Rscott View Post
I think I found a possible issue.
I went back to the FSM and looked up the ECM plug diagram. I proceeded to check everything to do with the AC.
AC switch off - 9-14v
AC switch on at idle 5v or more
Both tests were 0volts
The circuit it labeled ACT-E1. I wonder if that is actuation? I traced the wire blue/ yellow straight back to the amplifier.
I’m in the process of getting another ECM.
Pin 13 and Pin 25 off of the ECM goto your AC amplifier on the D connector.
13 should be a blue black wire.. 25 should be blue yellow wire
Which ac do you have the manual one ? or the automatic ? ( what does your dash controls look like? They levers or digital)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 08-01-2022, 09:49 PM #122
T4Rscott's Avatar
T4Rscott T4Rscott is offline
T4Rscott is on a distinguished road
T4Rscott's Avatar
Basic manual AC.
You’re correct on the wire colors. I just picked up a used ECM for 75.00.
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
T4Rscott is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 10:41 PM #123
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Basic manual AC.
Ok. I was going to give you the pinout on you ac amplifier so you can verify the wires have continuity. However, I know your going to try that other ecm.
Good job on not giving up as you will fix it and learn alot from this process.
Old 08-02-2022, 09:20 AM #124
T4Rscott's Avatar
T4Rscott's Avatar
I did the continuity test awhile ago. For some reason, I didn’t probe the ECM circuits.
Old 08-02-2022, 03:31 PM #125
I don't know which signal is which but that is part of the secondary communication between the AC amplifier and the ECU. You are on to something there.
One signal is the "AC wants to be on" from the amp and the other is the "Turn off the AC" signal to the amp.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-19-2022, 07:07 PM #126
T4Rscott's Avatar
T4Rscott's Avatar
Update
I did get another ECM and nothing changed on the clutch side, but….now it blows hot air.
I’m beyond angry.
Old 08-19-2022, 08:35 PM #127
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I’m beyond angry.
Good grief...:/
Old 08-19-2022, 10:11 PM #128
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Does the ac clutch even kick in with the other ecu?
Old 08-19-2022, 10:33 PM #129
T4Rscott's Avatar
T4Rscott's Avatar
No, it did the same thing, only when the throttle is depressed.
Good thing I can return it.
Old 08-19-2022, 10:41 PM #130
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Not the ecu then left with wiring and bad amplifier. That entire thing is crazy.
You still have pressure and referent in the system?
As you could have a leak and the 134a gone.
I had one do that to me that I need a new ac line for. As my actual line itself is damaged leaking the refrigerate.
I never seen your issue before. Now I greatful to have to only deal with the leaks problems.
I knew I should have grabbed that ac amplifier out of that 1999 ...
Old 08-19-2022, 10:49 PM #131
T4Rscott's Avatar
T4Rscott's Avatar
I have another amplifier. I swapped that too and no difference.
Old 08-20-2022, 08:34 AM #132
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Does it work with you original ecu? If not I trace those 2 wires that go from the amplifier to the ecu as something got worse here.
Old 08-20-2022, 09:45 PM #133
T4Rscott's Avatar
T4Rscott's Avatar
I put my original ECM back in an it was working on the gas pedal as usual. Today the clutch wouldn’t engage and I put the gauges on. It’s about 15 psi on the low side and 5 psi on the high side. The only part that glows is the manifold the the hoses connect to.
Maybe the compressor gave up the ghost? It wasn’t my original, in fact it was an aftermarket one
Old 08-20-2022, 10:19 PM #134
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You have a refrigerate leak on top of everything else. 15 is too low your pressure switch opened the safety switch so the compressor won't turn on.
Very possible the compressor has an issue as well. As 5 psi isn't good at all.
When my one compressor blew it was the same pressure on both sides. :/
Old 10-03-2022, 11:41 PM #135
T4Rscott's Avatar
T4Rscott's Avatar
Update
Just want to take a minute to update everyone on this issue.
I have been working with a local AC and radiator shop and I believe we are getting closer to an answer.
To date I have replaced the following:
-Condenser
-Receiver
-Evaporator
-Expansion Valve
-Pressure switch
-Thermistor
-Amplifier
-Swapped compressor ( my original is back due to a failed seal on the reman)
-I tried a new ECM with no effect.
As of today, the system does cycle, but only on the throttle. I went back to my FSMs and looked through the trouble chart again. One component I overlooked, the main heater relay. According to the manual, terminals 2-4 and 3-5 should have continuity. 3-5 did not get a beep. The relay energized when I put battery voltage to those terminals. Not sure how it’s possible. The manual states to replace the relay if it fails any of the tests. I have one coming in tomorrow.
I’ll let you know what happens….
Scott
compressor , issue , i’m , pressure , system
I'm baffled - Thunk, clunk, pop! WTH WRfarmer 3rd gen T4Rs 6 07-30-2019 03:25 PM
Help! Lean has me baffled... kdub351 5th gen T4Rs 29 04-02-2019 02:19 PM
Feeling Baffled. WeldTightFab 4th Gen T4Rs 1 07-27-2015 11:05 AM
My Mechanic is Baffled scrbear11 4th Gen T4Rs 17 07-28-2013 11:12 PM
I'm baffled... 1995 4runner dwighter Classic T4Rs 1 02-07-2011 01:50 AM
