Old 06-18-2022, 08:32 PM #1
T4Rscott's Avatar
T4Rscott T4Rscott is offline
T4Rscott is on a distinguished road
T4Rscott's Avatar
AC has me baffled…
Hey all,
I’m an completely baffled by my AC system.
I have gone through the entire factory service manual section on the AC system, and I have done all the diag, and it still won’t engage the compressor clutch at idle.
I had the the system flushed and refilled, I have replaced the pressure switch, the thermistor, the TPS, the IAC. Everything up to and including the ECU has been probed and tested.
The shop I used to evac and refill thinks it could be a weak magnet, I’m not buying into that. Someone else hypothesized to could be a pressure issue in the compressor.
Can anyone give me some usable advice? The next thing will be to swap in another compressor, and I’m not willing to undertake that without knowing if it’s going to solve the problem.
Thanks,
Scott
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
T4Rscott is offline   Reply With QuoteReply With Quote
Old 06-18-2022, 08:50 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Is the pressure the same on both high side and low side? If it does the compressor is blown. Does the pressure switch test properly?
If you supply 12 volt directly to the magnetic clutch does it engage?
If it engages this way, you getting cold air.
I haven't heard of a weak magnet. Mostly they engage or they don't.
All fuses good?
Old 06-18-2022, 09:42 PM #3
T4Rscott's Avatar
T4Rscott's Avatar
The shop I took it to said the pressures were good. The switch is new. The clutch does engage when powered from the battery.
Old 06-18-2022, 10:34 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Then the clutch is good.
Does your ac button light up?
Maybe that Removable button and the ac circuity. These have either a analog or digital circuity depending in the years. The early years have a relay in that circuit. The kicks on and off with the compressor.
Old 06-18-2022, 10:36 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Will the ac function with the ac clutch on? You get cold air cooling off?
Old 06-19-2022, 09:23 AM #6
T4Rscott's Avatar
T4Rscott's Avatar
Yes the AC button is working. It gives copious amounts of cold air when the accelerator is depressed and the AC amplifier kicks in.
And yes the amplifier is new as well.
I have literally done every test and diag for all the items that are most common and some that are not.
I’m leaning toward replacing the compressor and clutch
Old 06-19-2022, 09:50 AM #7
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
If you do, don't forget the expansion valve.
Old 06-19-2022, 09:52 AM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It’s hard to diagnose the ac system without knowing what the low and high side pressures are at idle and at 1500 rpm’s. Is the ac compressor clutch engaged at idle or does it only engage at higher rpm’s?
Old 06-19-2022, 03:10 PM #9
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Wait, you need to accelerate the engine to get the A/C system to blow cold air? If that's the case, either your pressures are too low or you have a restriction somewhere in the system (likely the expansion valve). Chances are that the vehicle is not seeing the pressures it needs to see and is turning the compressor off to preserve itself.
I would want to see pressures after it sits a couple hours, at idle w/o compressor engaged, at idle w/ compressor cycling, and at 1500rpm w/ compressor engaged. That should give you an idea of what you're dealing with if everything else is electrically good and functional.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 06:19 PM #10
kevincva kevincva is offline
kevincva is on a distinguished road
Crazy problem, but try this,
Key on, engine not running, turn AC system on. AC clutch should engage even though the engine is not running. You should here a click. If not try advancing the accelerator by hand under the hood and see if the clutch will engage then- should hear the clutch pull in. If that is the case then it could be related to the throttle position sensor. Usually the TPS will turn off the AC when the throttle is at the wide open position.
99 Limited 4wd e-locker Desert Dune Metallic
kevincva is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 08:22 PM #11
T4Rscott's Avatar
T4Rscott's Avatar
Only at high RPM
Old 06-19-2022, 09:16 PM #12
T4Rscott's Avatar
T4Rscott's Avatar
Nothing happened.
Old 06-19-2022, 09:51 PM #13
Real Name: Patrick
Real Name: Patrick
Only at high RPM
Around how many rpm’s will it engage? The weak magnet excuse doesn’t sound right to me. The clutch either engages or it doesn’t.
Old 06-19-2022, 10:03 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Man extremely odd that it only engages at high rpm only.
So what happens if you manually just keep in engaged via 12 volt bypass to the magnetic clutch. Will your evaporator produce cold air out your vents?
Or warm air.. As your expansion valve can plug from debris.
Will all that new it cant shouldn't be the ac circuit. With new pressure switches it shouldn't be those. your getting down to the ac button and your compressor clutch. As everything else has been changed... :/
Old 06-20-2022, 12:09 AM #15
T4Rscott's Avatar
T4Rscott's Avatar
The AC button lights up and is not flashing. I have not tried the bypass while running, only to actuate the magnet, which works. Would assume it would give cold air.
I’m going to try to run a bypass from the input for the original clutch to a newer unit and see if that makes any difference. If it doesn’t, I’m going to look into replacing the expansion valve.
I have even gone to the extent of replacing the IAC and TPS to rule that out.
compressor , issue , i’m , pressure , system
I'm baffled - Thunk, clunk, pop! WTH WRfarmer 3rd gen T4Rs 6 07-30-2019 03:25 PM
Help! Lean has me baffled... kdub351 5th gen T4Rs 29 04-02-2019 02:19 PM
Feeling Baffled. WeldTightFab 4th Gen T4Rs 1 07-27-2015 11:05 AM
My Mechanic is Baffled scrbear11 4th Gen T4Rs 17 07-28-2013 11:12 PM
I'm baffled... 1995 4runner dwighter Classic T4Rs 1 02-07-2011 01:50 AM
