Originally Posted by dbgnallRWD
...Usually the lower part if the outer connection is "pointing" at the ground but now is moved like 45 degrees.
I'm no expert but it sure looks different than mine. Like the caster is off. I assume this is what you meant by "pointing at the ground", where the tie rod connects to the wheel/hub/knuckle (told you I'm no expert!).
