Old 06-08-2022, 01:59 PM #1
alan.absalon alan.absalon is offline
alan.absalon is on a distinguished road
1997 4runner with 260k miles for $5500
I saw this 1997 3RZ-FE 2.7L 4X4 Automatic 4unner on sale in the California central valley for $5500. What are your thoughts on this rig in terms of long term ownership, say seven to ten years, as well as an overlanding rig? It has 260k miles on it with the original engine, one owner according to the carfax, and never been involved in an accident.
I attached pictures of the 4runner I'm talking about.
1997 4runner with 260k miles for 00-received_3116906748533103-jpg  1997 4runner with 260k miles for 00-received_1614032175623387-jpg  1997 4runner with 260k miles for 00-received_1351466041947052-jpg  1997 4runner with 260k miles for 00-received_1022191855054743-jpg  1997 4runner with 260k miles for 00-received_994782914490697-jpg  1997 4runner with 260k miles for 00-received_992389684985670-jpg  1997 4runner with 260k miles for 00-received_963755224317378-jpeg  1997 4runner with 260k miles for 00-received_919257635417681-jpeg
alan.absalon is offline   Reply With QuoteReply With Quote
Old 06-08-2022, 02:02 PM #2
more pictures
more pictures
1997 4runner with 260k miles for 00-received_919257635417681-jpeg  1997 4runner with 260k miles for 00-received_764851524902069-jpeg  1997 4runner with 260k miles for 00-received_764145211636197-jpg  1997 4runner with 260k miles for 00-received_713490560010166-jpg  1997 4runner with 260k miles for 00-received_695840304900573-jpg  1997 4runner with 260k miles for 00-received_668646437704562-jpeg  1997 4runner with 260k miles for 00-received_667672250957525-jpg  1997 4runner with 260k miles for 00-received_649313492796363-jpg
Old 06-08-2022, 03:33 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The 4-cylinder 3RZ engine is a bit underpowered but it'll get the job done, just don't expect to tow anything with it or be able to cruise at 70 MPH up the pass into the Sierras with a load of camping gear. The 4Runner looks clean enough but at 260K miles it's not the engine you'll be concerned about. Steering and suspension parts will start to wear out and break at that mileage. Accessories like the alternator, for example, might fail. It's nothing that will cost $1000's to replace but you will find yourself working on it. If you have the space and tools, great. If you do not, I would suggest looking for a lower mileage one if you can afford it.
326WHP 347TQ
Old 06-09-2022, 01:52 AM #4
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
^^This is a realistic assessment.
It's in good cosmetic shape (no rust) so the price is about par for today's market. Keep in mind that [most likely] it will immediately need new springs and shocks. New LT tires if you want to 4 wheel it. New radiator and lower ball joints are a priority. Auto trans might be OK for another 100K miles, or if they are selling it because it had a pink milkshake event, the trans could take a dump next week. Many unknowns...complete service records might help you decide.
pluton is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 06:43 AM #5
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
It's not miles that's the issue with 3rd gens, it's the time since they were built. Arguably, a low mile example could be in MUCH worse condition than a high mile simply because maintenance isn't done "because it's low mile", but all the rubber hoses/seals/bushings still age.
And it cost me about $3000 to baseline my '99, doing ALL of the maintenance items that are known and common issues... and that's just parts costs, I did all the labor but changing the tires and an alignment. All bushings, new suspension, radiator, timing belt, crank and cam seals, valve cover refresh, vacuum lines, trans filter, etc... Just a mechanics mentality, I'd rather do it up front then find it was an issue while out and about (plus, this is my wifes DD, you do *NOT* want your SO to be stranded if you enjoy a calm and peaceful life). I did splurge on suspension with the Bils 6112/5160 combo, and didn't opt for the Cheapest tires out there which accounts for $2k, but the rest of that cost was nearly all OEM parts.
OP, so long as you know what you're getting into and are willing/able to do the work yourself, you'll be fine. If not, you might want to look for something Newer. I'm in GA, and the 4th gens (v6, 4x4, mid 200k miles) are half the price of the 3rd gens at about $4k. Newer vehicle means less important to do any/all undocumented maintenance Right Now, plus more $$$ to do that work. I think they fixed the LBJ issue for that gen too...
Brian. is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 08:03 AM #6
19963.4lsr5 19963.4lsr5 is online now
It be interesting to know the reason it’s for sale if it’s a private sale.
First thing I usually do is plug in my scanner and see if all the readiness monitors are set. If they are not and the battery isn’t brand new I walk. It means they reset the check engine light.
Then I check fluid levels and pull the trans dipstick to look at its color and smell.
After that I’ll walk around the vehicle.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 06-09-2022, 08:30 AM #7
Aren't the 3rz 4 cylinder engines more reliable than the v6 5vze?
Old 06-09-2022, 08:53 AM #8
jgue467's Avatar
jgue467 jgue467 is online now
jgue467's Avatar
Not that I've read on here since early 2010 or am aware of.
If anything its the other way around.
My 5vz is at 340K, uses virtually no oil between 5K OCIs, pulls hard, keeps up and exceeds most traffic and has given me little issues other than one blown out sparkplug.
If driving at sea level and levelish roads it'll probably be acceptable, otherwise I'd hunt for a far more common 5vz. I'd also look for one with the bigger brakes from the factory, the ones that come on 16" OEM wheels, so some SR5s and all Limiteds have them. Luck.
jgue467 is online now   Reply With QuoteReply With Quote
Old 06-09-2022, 11:30 AM #9
340k miles with original engine?
Old 06-09-2022, 01:34 PM #10
Brian.'s Avatar
Brian.'s Avatar
I wouldn't be surprised... LOTS of original engine 300k+ rigs in this forum, a few 400K+
Old 06-09-2022, 03:12 PM #11
JZiggy's Avatar
JZiggy JZiggy is online now
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Similar levels of reliability. Maintenance is easier on the 3RZ and it gets a touch better gas mileage, but that's about it. All the 3rd gen drivetrains are rock solid.
JZiggy is online now   Reply With QuoteReply With Quote
Old 06-09-2022, 03:45 PM #12
Would you get this 4runner for $5500? Is it a good buy? Should I be worried about maintenance?
Old 06-09-2022, 04:06 PM #13
JZiggy's Avatar
JZiggy's Avatar
It’s not a bad price for what it is. Nothing on these trucks is hard to fix and there are lots of resources here. Budget another $2k to really update the maintenance and do some fun upgrades.
Old 06-09-2022, 04:40 PM #14
Most definitely. If I get the 4runner, I will budget around $5000 to take it to a family mechanic and really update the maintenance. I plan to keep it stock because it will be a daily driver.
Old 06-09-2022, 04:53 PM #15
I plan to take it to a family mechanic. Is $5000 enough to update the maintenance?
$5500 , 260k , 4runner , miles , rig
Help! 260k miles, check engine light, multi terrain light, and slip indicator light dave_b 5th gen T4Rs 21 01-19-2021 09:20 AM
FS 3rd Gen 1999 sr5 4x4 $5500 New Orleans <100k miles NOLAcat For Sale: Vehicles 3 11-09-2016 12:15 AM
