Old 08-20-2022, 11:58 AM #16
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Originally Posted by chapolito View Post
@Bad Luck @TracyNorton bit the bullet and swapped in a new OEM TPS. Unfortunately no change except idle reading now at 11% vs 11.8%. Was only $60...was looking at the wrong part number at first, ended up with 8945235020 At least I now have a spare one? lol Getting those screws off/on was a mild PITA though...ended up using a phillips bit in visegrips.
@UnderFire Regarding cleaning the grounds—I tested the resistance between the battery negative and each ground and all were low. I assume this is an indication of proper connection to the chassis?
Checked the plugs and all looked clean.
Well crap... Back to the drawing board. What a strange issue
Bad Luck is online now   Reply With QuoteReply With Quote
clutch , fluid , miles , replaced , transmission
Manual Trans Gear Oil Gerdo Maintenance/Detailing 23 07-05-2018 11:50 PM
4th and 5th gear are sluggish 2000 sr5 manual nalbertasr5 3rd gen T4Rs 0 04-25-2016 10:14 PM
5 Speed Manual Pops out of 1st Gear.. Hmmm?? sephryan Classic T4Rs 6 04-04-2013 03:36 AM
Manual Transmission: Hard to get into 4th gear (and somewhat 1st). Diagnosis? nobb 3rd gen T4Rs 7 03-26-2013 11:29 PM
Manual Trans Gear Oil Gerdo 3rd gen T4Rs 4 11-30-2010 01:11 AM
