Old 06-25-2022, 06:42 PM #1
NYState4Runner NYState4Runner is offline
NYState4Runner is on a distinguished road
Wheel Spacer Plates ( no Studs just plate)
Good Afternoon All,
I was wondering if anyone out there has purchased any 0.25" - 1" plates with NO studs, just holes / slots for the OEM studs to fit through?
Ref Link:
https://www.amazon.com/KSP-Universal...Toyota+4Runner
If You did use one of these plates, which thickness will still provide enough bite for the wheel nuts to grab the lugs? I am going this route to avoid the aftermarket studs found on larger wheel spacers. I am just trying to move the wheel face over a tad to fit 33" with no UCA rub, not really for looks.
I understand that if you install the studded wheel spacers that they wont necessarily come loose; but I have seen the literal studs snap and wheels roll down the highway. Those aftermarket studs on the spacers seem to not handle the fatigue well over time.
You will only sway me if you can find me forged hub+lug centric (same as OEM fitment) with ARP / forged studs. Else wise I think the spacer plates make more sense with perhaps just buying longer OEM studs...
Let me know if you are out there and have experience with the non studded spacer plates.
NYState4Runner is offline   Reply With QuoteReply With Quote
Old 06-25-2022, 10:07 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Originally Posted by NYState4Runner View Post
Good Afternoon All,
Ref Link:
The stock wheel studs aren’t long enough to go more than 1/4” inch spacer safely. Even if you have longer studs a thicker spacer will stick out past the centering bore portion of the hub face so you won’t be hubcentric anymore.
Spacers with studs have come a long way since the sketchiness when they first came out. A lot of those failures were due to installation error and not retorqueing them shortly after installation like you’re supposed to. Stick with a known brand like spider trax and I doubt you’ll have any issues with them.
Old 06-25-2022, 10:47 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold
Devbot's Avatar
Real Name: Devan
I have a set of what are often called "wheel shims," which are 3mm thick (roughly 1/8"). They're intended to help fit wheels around brake calipers if you're rubbing, so if you're looking for just a little extra bump in that regard that's what I'd look into, you can find them in hub-centric.
If you were looking to widen your track width and don't want 1.25" spacers I suggest looking into wheels with a different offset. Otherwise I don't see why you wanna avoid them, I kinda wish I got them instead of just wider wheels
Y2K Highlander Millennium Silver 3.4L auto @ 300k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / EimKeith PCK + LCAR / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / CBI Hybrid Bumper + Tire Carrier / 4xInnovations Sliders / Smittybilt XRC Gen 3 Comp. / Opt Offroad Trailing Arms / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
oem , plates , spacer , studs , wheel
spidertrax spacer studs, need longer ones orbot 3rd gen T4Rs 0 06-16-2022 11:10 PM
Spacer install short studs cflipper 4th Gen T4Rs 12 08-22-2018 11:03 AM
top plate studs, for top hat on struts the great him 3rd gen T4Rs 3 10-30-2012 01:06 AM
Extended Studs Without A Spacer? SCRunner12 3rd gen T4Rs 6 08-23-2011 04:45 PM
WTB: Top Plate spacers and/or extended studs saulgoode Want to Buy/Trade 0 10-17-2006 12:04 PM
