Originally Posted by AZZTR0CREEP
yes, while its running on starter fluid the rpm go up and shows the rpms until its out of fumes. im curious what that tells you. i still havent dropped the gas tank to check the pump yet. i removed the fuel filter and cranked the engine but its not blasting out of the line. it dribbles out mostly.
That should tell you that your fuel pump isn't working right. You most likely need a new fuel pump.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
