Old 07-14-2022, 07:42 AM #16
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Originally Posted by ZSW99 View Post
Yeah interesting. Those are pretty impressive travel numbers for a mono tube shock. The gas volume must be pretty low which means it will have more ramp up deep into the travel. Maybe not the best for slow crawling and maxed flex but probably an advantage for general driving and faster off-roading
Well the 4th gen shock is physically longer so that is where the travel comes from.
Also, for those who are interested, dobinsons has shipped me a pair of 4th gen shocks with custom valving they believe should ride plush for a 3rd gen. Wooooo!
As soon as they get here and I get them put on and tested, I will post my review about them.
Old 07-14-2022, 01:38 PM #17
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
Looking forward to the results!
Dob quoted me about $100 to re-valve a 4th Gen set, it that about right?
That does up the overall cost quite a bit...
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 07-14-2022, 06:45 PM #18
jross20's Avatar
jross20's Avatar
I did not actually pay anything extra, however it might be that they wanted to do this because I told them that I would share and review on the forums because it seemed like a lot of people were interested.
I mean honestly though, I still think that's very fair if they actually do ride really well because then you have shocks that ride fantastic and the travel is great. Well again, hopefully they ride fantastic.
They will be here either tomorrow or Friday and I'll try to get them installed as soon as I can.
Old 07-16-2022, 10:50 AM #19
jross20's Avatar
jross20's Avatar
All right so some updates, I received the shocks and they look pretty awesome. I still need to get new top hat washers though...
I'll post some pictures here soon
Old 07-16-2022, 11:19 AM #20
jross20's Avatar
jross20's Avatar
In order
  • Stock Rears
  • 4th Gen IMS Rears
  • OEM LC Shocks
Also, does anybody remember what the bolt hole size should be on the bottom of the shot? This is one thing that I forgot to confirm with Dobinsons and I'm hoping that they might have already swapped it out. It looks like it's around 19 mm internal diameter.
Old 07-16-2022, 11:57 AM #21
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by brillo_76 View Post
Worst case you could drill the the hole in the shock coil plate longer if you have too. I am not sure of its diameter though.
Outboard shock mount
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 07-16-2022, 12:11 PM #22
The LC shock uses the same size bottom bolt as stock, just compare to that but I suspect they accounted for that since you discussed 3rd gen with them.
FWIW, I'm running LC shocks and did not drill out the top mount but I'm also not using the LC centering washer. I made a 1.2" copper shaft bushing for the pocket and used a 3/8" hose over the shaft and stacked the LC dampeners over that. This holds the shaft centered and allows flex and articulation.
Old 07-16-2022, 12:24 PM #23
jross20's Avatar
jross20's Avatar
Oh wow that sounds cool.
Yeah I still want to get a picture showing the flex limitation with the stock top hat washer between the 3 shocks I have. Not exactly scientific testing but good enough visual testing.
Old 07-17-2022, 12:25 AM #24
ZSW99 ZSW99 is offline
ZSW99 is on a distinguished road
That’s what’s interesting though, it’s only 1/2” longer on the compressed length but has like 2” more travel. Fitting 9.25” of damper rod into a 14” compressed length is surprising to me at least
99 SR-5 Highlander Elocker, 1.5” body lift, Ironman FCP coilover, FJ cruiser bilstein lift coils and fj80 kyb rear shocks, JBA ucas, TC gussets, custom front & rear tube bumpers, poly bushings all around, 33/12.5/15 on steels. 396k
98 Base 4x4 3rz. 5100s and ome coils. TBU. 360k
96 Taco rcsb 4x4 3rz 320k
ZSW99 is offline   Reply With QuoteReply With Quote
Old 07-17-2022, 03:47 PM #25
jross20's Avatar
jross20's Avatar
Perhaps it is improved technology? Perhaps certain parts can be made thinner without compromising structural integrity? Or perhaps some shots like the Land cruiser ones are not as optimized as they could be? As in, maybe it's bulkier than it really needs to be because it was cheaper or something.
I wish we had a guy with one of those like water cutting machines, somebody that could like take shocks and cut them in half long ways.
Old 07-20-2022, 10:03 PM #26
jross20's Avatar
jross20's Avatar
Alright, finally got the damn shock top hat washers.
I've got a local ship who quoted a good price on swapping the rears so now that I've got all of the goods I'll work on scheduling with them. As much of a pain in the ass the rear shocks are and with how hot it is down here... I'll gladly let them do it... haha.
I am actually a bit worried about the coils being too short...hopefully they are not. Does anyone know if rear wheel travel is higher during flexing than just having the truck up in the air?
Old 07-21-2022, 12:29 AM #27
I think it depends on what kind of rear links you have and if you have a sway bar. If you have a sway bar and your not running modified links I don’t think the travel will be much more being flexed vs drooping. Sway bar is probably the first thing to bind and limit the travel
Old 07-21-2022, 07:57 AM #28
jross20's Avatar
jross20's Avatar
Ah I see. Hopefully that holds true. Though the free length of the 890 is pretty tall this might push it to the limit... Haha. Keep your fingers crossed that the good coils don't get loose when I do a flex test after installation.
I'm also going to take and post pictures from my rod diameter testing today when I get the chance. It's actually pretty wild, assuming the old shocks that I have are OEM... their articulation within the confines of the top hat washer/shim is pretty much insane. Probably way more than you would ever need.
You know I think somebody said the stock upper shaft is 10 millimeters, I'll get my caliper out and see if this one is because it definitely seems crazy small.
Old 07-21-2022, 01:32 PM #29
Travel at the springs is less when flexing (inboard of the shocks), travel at the wheels is more when flexing (outboard of the shocks).
Jumping/bouncing is when springs fall out in the rear, generally.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-21-2022, 06:56 PM #30
jross20's Avatar
jross20's Avatar
Previously when I had 906's they become loose at full flex. i.e. full flex being driving up a steep hill and one rear tire flexing down while the other compressed up. Once I switched to 890's the problem went away. I mean I could just about remove the coils while she was flexed lol.
4th , gen , ims , shaft , shock
Rear shock, upper bushings? Luke325i 3rd gen T4Rs 6 07-27-2019 01:03 PM
Rear upper shock mount 2005v8limited Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-09-2019 07:03 PM
Rear upper shock mount jstim 3rd gen T4Rs 4 06-18-2017 11:31 PM
rear upper shock mount CSM4runner 3rd gen T4Rs 9 02-07-2017 06:51 PM
Rear upper shock mount? SilentYoda3 3rd gen T4Rs 15 08-30-2013 12:10 PM
