Old 07-21-2022, 07:45 PM #31
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
Originally Posted by jross20 View Post
Previously when I had 906's they become loose at full flex. i.e. full flex being driving up a steep hill and one rear tire flexing down while the other compressed up. Once I switched to 890's the problem went away. I mean I could just about remove the coils while she was flexed lol.
The 906's are pretty short - definitely need to have stock length shocks for them. I have 5th gen springs, and they are even shorter! Even with a 10mm trim packer, they are loose at full droop with 5100's (stock length). I'm planning on moving to 906's at some point - I don't need the extra travel and I could use the progressive winding for better weight handling.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-22-2022, 07:55 AM #32
jross20's Avatar
jross20 jross20 is offline
jross20 has a spectacular aura about jross20 has a spectacular aura about jross20 has a spectacular aura about
jross20's Avatar
You know I honestly thought that the 890's rode much better than the 906's. I've loaded the back with a decent bit of stuff a few times and the 890's have never sagged. I've never had a trailer hooked up but I do want to check that out and see how they handle it
Old 07-23-2022, 11:06 AM #33
jross20's Avatar
jross20's Avatar
All right so here's my super non-scientific comparison shots.
They're not exact but they should give you a pretty good idea. Clearly the stock shot has ridiculous articulation, but I'm pretty sure that it would never need anywhere near that much. If somebody can post a picture of what their rear shocks look like at maximum flex I think that would give us a good comparison. As in, sure the Dobson doesn't have as much articulation, but is it still more than enough for what's actually going to be usable?
Stock w/ 10mm Shaft:
Dobinson 4th Gen w/ 12mm Shaft:
Old 07-23-2022, 12:42 PM #34
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Probably still more articulation than would be usable or needed. So what did you end up doing for the centering cone/washer and bushings?
Old 07-23-2022, 01:18 PM #35
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
The 906's are shorter but stiff so a softer stock length shock is required if you want a smoother ride. If you were using the LC shocks with those they are way too long. The 890's are taller but can be bouncy without some weight in the back or a stiffer shock from a heavier truck like a 4th gen or LC. Now to confuse you more, 890's will sag overtime if you put a lot of weight in the back like an aftermarket bumper with tire carrier. Also your stance loaded and unloaded might be important to you. Just think about the future mods you have planned where you will be adding weight. You dont want to do your lift a second time. I read hundreds of lift threads for a year before I decided I what my best options would be. Those lift threads have opinions from owners that have used all kinds of combo's and you can learn a lot from guys that have redone their lifts 2 and 3 times! LOL Dont forget tires have a big effect on ride quality. E rated truck tires ride like shit on our rigs. But if you have a short ride to the trail, dont DD it and wheel every weekend they're gonna be fine. If you're mostly a pavement princess, pass or C rated tires would be better. I have pass rated HWY tires on my Limited because it never goes off road. They're quiet, comfortable and get great MPGs. My lifted 4runner has D rated mud tires because its 50/50 pavement/off road and I have very long drives to the trails. Good Luck!
PS: Thousands of forum members here have used 4th gen Bilsteins with 890's over the years with no issues. I dont see why the Dobninsons would be a problem?
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 07-23-2022, 02:04 PM #36
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing will become famous soon enough
GhostRing's Avatar
Gettin' there!
Slightly random questions: Say I get the 3rd gen valving - but decide to outboard mount these, how much (if any) am I affecting the damping?
In my head, the outboard puts the shock more perpendicular to the axle, potentially changing the rate of compression. Am I overthinking that?
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 07-23-2022, 03:53 PM #37
ZSW99 ZSW99 is offline
ZSW99 is on a distinguished road
I just jacked mine up until my coil was loose enough to fall out and it looked similar to what your showing with the dobinsons shock so I’d say you are good.
12mm Rear Shock Upper Threaded Shaft-e08156cd-0cde-482e-9614-148112342ce3-jpg
99 SR-5 Highlander Elocker, 1.5” body lift, Ironman FCP coilover, FJ cruiser bilstein lift coils and fj80 kyb rear shocks, JBA ucas, TC gussets, custom front & rear tube bumpers, poly bushings all around, 33/12.5/15 on steels. 396k
98 Base 4x4 3rz. 5100s and ome coils. TBU. 360k
96 Taco rcsb 4x4 3rz 320k
ZSW99 is offline   Reply With QuoteReply With Quote
Old 07-23-2022, 06:07 PM #38
jross20's Avatar
jross20's Avatar
If you hadn't seen it, a few pictures back I actually showed that The doninson shock has longer travel than even the Land cruiser shock. Something like 9.25" of shock travel! In fact I think it's the longest that I've ever seen for 3rd gens.
You know I did spend a lot of time in the past but even though I did, I still ended up changing things later because even though I did a bunch of research I still learned additional things later that I never thought to search for... But I guess that's just how it goes.
Although really, is there anything else besides the 890s? In terms of if you wanted something just as long or maybe a little longer?
Originally Posted by GhostRing View Post
Gettin' there!
I'm not 100% sure either, but at the same time I would like to say that it would make sense if it did affect it. That would also change the length of shock you would need so you would probably really need to mock it up to see what kind of overall travel you need.
You know I've been thinking about this... I wonder if there's any way that some kind of a simple stimulation could be made that could allow us to simulate travel on the axle. Like if somebody who knew how to code or something wrote some basic little program and we put in the exact dimensions and everything of the frame and the axle. Something that would let you click and drag and like drag it around so you can get measurements and stuff.
Old 08-02-2022, 09:35 AM #39
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
LC springs
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-18-2022, 08:04 AM #40
jross20's Avatar
jross20's Avatar
Originally Posted by octanejunkie View Post
LC springs
Which year? By chance do we have specs on them? Specially the free length.
Old 08-18-2022, 02:14 PM #41
Real Name: Patrick
Real Name: Patrick
Lots of options depending on color code/year/trim
LC coil spring Color codes
LC color codes
Help Identifying Coils
Old 10-01-2022, 04:27 PM #42
GhostRing's Avatar
GhostRing's Avatar
Getting antsy to try out the shocks, so I would like to hear some thoughts on this?
My 50701's (which Dobinson's stated to me directly are the newest valving) came with a set of bushings for a Toyota Fortuner.
As you can see, the kit came with 2 washers & 2 bushings. No Centering/Index washer, or indication to use one.
They are also a softer compound that the 4th Gen bushings.
What is the drawback to simply installing it just like this? I figure any index washer essentially "becomes" the hole in the frame, and keeps
the shock shaft completely isolated in the bushing stack. That to me is the primary goal to allow safe movement as the post pivots inside the frame hole.
The combined height of the Fortuner bushing shoulders is equal to the bushing/washer intended for the 4th Gen T4R,
and the 17mm shoulder diameter equals the 3rd Gen frame hole. This (in theory) should still isolate the shaft during use, correct?
I do have the following concerns:
Index washers seem to exist for a reason, but I can't quite get my head around it...If they are sufficiently tensioned,
they should effectively be one with the shock frame hole. (imagine welding the washer in place)
I assume it shouldn't move at all during the shock cycle.
Is it simply the needed method to be able to utilize a cupped washer?
I am worried that under full articulation, the bushing will try to smush out
against the frame plate instead of staying tucked into the washers.
@ZSW99 image illustrates this bushing containment.
Second, due to the larger post diameter, the Fortuner bushing shoulder is
thinner than the 4th Gen's. Too thin? I mean Dobinsons provides these to
be utilized on a similar, alternate vehicle, so it's apparently acceptable...
So I am going to chuck these under there and see what happens.
I don't see the post snapping off suddenly, but the bushing shoulders
may not hold up. I know these are wicked long shocks, but between
the 890s and ext. bumpstops, I should hopefully stay out of trouble.
I figure at least this lets me see if the valving is even close to what I want
without having to drill out OEM holes, or fab up outboard mounts yet.
Build Etc...
Old 10-01-2022, 09:39 PM #43
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
dunno if this has a bearing on the behavior of your shocks. but the fortuner has its rear shocks located behind the rear axle and coils are seated on the rear LCAs.
also, I am not sure about those bushings being able to hold out against the loads applied to it. I would rather have the stock cushion retainer if it works with the dobinsons shocks.
OME recommends that the stock cushion retainer be used with their bushings to ensure that the shock shaft is centered on the hole.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 10-02-2022, 07:30 AM #44
jross20's Avatar
jross20's Avatar
I'd have to get under there to see exactly what I used, but I basically used a combination of the washers and bushings that they sent with actual OEM ones. So like I did use the OEM centering washer.
Yeah I definitely would not install anything without using the proper centering washer!!
Old 10-02-2022, 08:00 PM #45
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
If you torque down the bushings enough, they will squeeze in the hole and become a sort of 'centering washer' all on their own. However I don't know how you plan on driving your vehicle so if you expect the rear shocks to do a lot of work, meaning off-road a lot, it may not work and be secure enough. My reference on this is the sway bar bushings as if you torque them down tight enough they will squeeze into the recess around the threaded bolt and fill the gap on their own.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 240K miles.
326WHP 347TQ
4th , gen , ims , shaft , shock
Rear shock, upper bushings? Luke325i 3rd gen T4Rs 6 07-27-2019 01:03 PM
Rear upper shock mount 2005v8limited Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-09-2019 07:03 PM
Rear upper shock mount jstim 3rd gen T4Rs 4 06-18-2017 11:31 PM
rear upper shock mount CSM4runner 3rd gen T4Rs 9 02-07-2017 06:51 PM
Rear upper shock mount? SilentYoda3 3rd gen T4Rs 15 08-30-2013 12:10 PM
