Getting antsy to try out the shocks, so I would like to hear some thoughts on this?
My 50701's (which Dobinson's stated to me directly are the newest valving) came with a set of bushings for a Toyota Fortuner.
As you can see, the kit came with 2 washers & 2 bushings. No Centering/Index washer, or indication to use one.
They are also a softer compound that the 4th Gen bushings.
What is the drawback to simply installing it just like this? I figure any index washer essentially "becomes" the hole in the frame, and keeps
the shock shaft completely isolated in the bushing stack. That to me is the primary goal to allow safe movement as the post pivots inside the frame hole.
The combined height of the Fortuner bushing shoulders is equal to the bushing/washer intended for the 4th Gen T4R,
and the 17mm shoulder diameter equals the 3rd Gen frame hole. This (in theory) should still isolate the shaft during use, correct?
I do have the following concerns:
Index washers seem to exist for a reason, but I can't quite get my head around it...If they are sufficiently tensioned,
they should effectively be one with the shock frame hole. (imagine welding the washer in place)
I assume it shouldn't move at all during the shock cycle.
Is it simply the needed method to be able to utilize a cupped washer?
I am worried that under full articulation, the bushing will try to smush out
against the frame plate instead of staying tucked into the washers.
ZSW99
image illustrates this bushing containment.
Second, due to the larger post diameter, the Fortuner bushing shoulder is
thinner than the 4th Gen's. Too thin? I mean Dobinsons provides these to
be utilized on a similar, alternate vehicle, so it's apparently acceptable...
So I am going to chuck these under there and see what happens.
I don't see the post snapping off suddenly, but the bushing shoulders
may not hold up. I know these are wicked long shocks, but between
the 890s and ext. bumpstops, I should hopefully stay out of trouble.
I figure at least this lets me see if the valving is even close to what I want
without having to drill out OEM holes, or fab up outboard mounts yet.
