Old 06-29-2022, 01:22 AM #1
AdrianBrewster AdrianBrewster is offline
AdrianBrewster is on a distinguished road
Issues with aftermarket extended brake lines?
Has anyone had any issues with extended brake lines not threading as deeply as the OEM? The OEM lines were original and a pain to get off but they seemed to thread in pretty deep. These on the other hand (from SRQ fabrications) only seemed to get 2-3 turns before getting tight. 8”I’m concerned I may have stripped the first one a bit overtightening it. It just didn’t feel right only having a couple of turns in on a brake line! I’m showing 6 threads on 3 connections and 5 on the other, which also happens to be the one I really torqued down on and may have stripped.
AdrianBrewster is offline   Reply With QuoteReply With Quote
Old 06-29-2022, 09:01 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I always compare the line nuts. Some are alot longer then others. However the flange should be the same depth as in as the original.
If I make line, I use only stainless steel line nuts and Nickle copper lines. I belive the thread is 10mmx 1.0. I do this as I live in the rust belt.
You maybe better off to just get the oem lines you need from Toyota. As they are all prebent and have the same nuts as the oem original do. I believe they are all available yet.
Ah. Aftermarket extensions. So my information is not applicable to your need. Sorry. Thankfully the other member has it handled.
Old 06-29-2022, 11:47 AM #3
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
This is a common issue. If you search, you'll find several threads about it.
What I did:
Try threading the banjo bolt into the caliper without the brake line to confirm if it will bottom out properly or not.
It's not the threads of the bolt that are too long though, the inside diameter is what will interfere.
It's an easy fix. All you have to do is slightly drill out the end of the banjo bolt to provide a little relief. Then recheck the bolt in the caliper, and you'll be good to go.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
brake , issues , lines , stripped , turns
Extended Brake lines Morphyne 4th Gen T4Rs 4 07-23-2018 03:20 PM
Extended Brake Lines - What have you used? Cypher 5th gen T4Rs 4 04-01-2015 01:26 AM
Extended brake lines. Yes or no? Kuzmovka Classic T4Rs 20 02-21-2014 04:27 AM
Will i need extended brake lines? murdarunna19 3rd gen T4Rs 5 03-26-2013 03:09 AM
WTB: extended brake lines 4th gen Bangers Runner Want to Buy/Trade 2 12-04-2009 01:01 PM
