Old 07-04-2022, 12:28 PM #1
Auce Auce is offline
Auce is on a distinguished road
Power window panel with lights/design flaw?
I took mine apart last night to see if I can get all 4 buttons glowing. I noticed that the older models (mine is an 01) and mine have completely different motherboards and switches.
My panel backing has one clear lense which I highlighted in yellow. So it's the only button that will light up green, the other 3 don't shine up at all. It makes zero sense to me why 1 out of 4 buttons would be like this?
Power window panel with lights/design flaw?-img_3398-jpg
Auce is offline   Reply With QuoteReply With Quote
Old 07-04-2022, 12:36 PM #2
For some reason when I try to upload more then one photo it fails.
Old 07-04-2022, 01:23 PM #3
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
try Imgur, I always have good luck there if I can't upload.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 07-04-2022, 11:16 PM #4
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The 01 and 02 went to pure digital controls instead if the old along switches and systems of the earlier gen years. This is why they are so different.
Why they didn't make all the buttons slightly Illuminate beyond me. :/
Maybe try glow in the dark stickers on the other buttons? As you can see how different it all is.
Might be able to mod some leds on the other switches too.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 07-05-2022, 12:29 AM #5
Thanks Brillo, so you are aware about all the buttons not illuminating? I'm with you as it's totally beyond me.
Old 07-05-2022, 05:06 AM #6
Shepherd214 Shepherd214 is offline
Shepherd214 is on a distinguished road
I added led's to mine. Passenger side had me scratching my head though. Turns out that the light goes out when you hit the window lock button.
Power window panel with lights/design flaw?-20210811_233426_hdr_resized-jpg
Shepherd214 is offline   Reply With QuoteReply With Quote
Old 07-05-2022, 09:33 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Worst case...you can run a dash light wire over through your door boot and Illuminate with it.
I would carefully look over the wiring diagrams for your years.
I haven't messed with my 01 sport much except to replace its rear diff and fixed rust..
I just know they are all digital. This is why your seeing cucuit boards instead of just switches...;)
Old 07-05-2022, 10:04 AM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I just Feel for it like everything else....pretty much know by location what the switches are for, just like the radio, don't need to Look at it to operate, that is the Beauty of it all to me....
Old 07-05-2022, 10:07 AM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That's what I mostly do. As I am watching the road... . But I mostly drive the early years around..
Old 07-05-2022, 11:35 AM #10
Shepard how did you add more LED's? Did you need to solder them on?
Old 07-08-2022, 01:16 PM #11
I soldered in two.
Power window panel with lights/design flaw?-20210810_211522_hdr_resized-2-jpg
Old 07-08-2022, 01:57 PM #12
I soldered in two.
Even if I soldered in 2, my backing still does not have the clear lens for it to illuminate.
Old 07-08-2022, 02:48 PM #13
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Seems much to do about nothing. There are only 6 switches and a mirror control on the door, and its not hard to find the correct one in the dark.
The reason Toyota didn't backlight them all is cost. The cost of adding a backlight plus more complicated window switches was not something that Toyota thought was necessary. The PCB design would also have to be more complicated to allow for extra LED, and then that adds to BOM.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 07-11-2022, 01:27 AM #14
On my 2002 just left rocker illuminates. On the right one you have to drill a hole under the lettering to let the light thru and install a clear lense to focus the light up. If you take off the switch rockers you'll see what I mean.
button , buttons , light , mine , panel
Fatal Design Flaw '01-'02 4Runner Brake Master Assembly $3k Mutant 3rd gen T4Rs 64 02-09-2023 11:59 PM
BALL JOINTS: Sankei 555 (Moog/Raybestos) Poor Quality/Design Flaw??? My Findings... nobb 3rd gen T4Rs 102 02-26-2022 03:54 PM
Wheel Arch Design Flaw? 4runner2014 Problems & Warranty Issues 1 12-30-2014 11:10 AM
Return Fuel Line Design Flaw Sgt. Russ 3rd gen T4Rs 19 07-06-2014 11:53 PM
