Originally Posted by Bad Luck
The product description states "There should be a ½” to 1 ½” gap between rubber spring and frame to ensure unloaded ride quality" so you may need to get taller springs or spring spacers for the rear to achieve the recommended gap. Something to keep in mind.
That'll depend on the year. My 2WD was at ~20" all around, even at 15+ years old. Ride height between the 2WD and 4WD is basically the same (other than the '99 4WDs).
Another option for towing and not much lift is the OME 2906 springs, but they will be a 2" lift unloaded (~22" hub center to fender lip).
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
