Old 07-11-2022, 09:29 PM #16
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by phattyduck View Post
It can if it is way loose
How so, if your pedal/hydraulics are in no way tied to the cable?
Granted I don't have drum brakes memorized.
Old 07-11-2022, 09:34 PM #17
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
If your ebrake cable is loose and doesn't move the brake shoes when you pull it, then the autoadjusters on the drums don't do their job, and you can end up with weird pedal feel due to the longer shoe travel that then causes.
EDIT: The same thing can happen if you just don't use your parking brake.
Skulking is offline   Reply With QuoteReply With Quote
Old 07-11-2022, 10:39 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have seen the bellcranks frozen and the cable seized which will not let the adjuster auto adjust the rear brake shoes. If this happens or you don't ever backup using your e brake on occasion The shoes continue to slowly wear down increasing your pedal travel because the wheel cylinders have to more fluid to move to apply the brakes in the drums.
Before, I fixed my emergency brake properly, I would check my rear drums ( every 5K miles ) to make sure they slightly dragged. If they didn't I would manually adjust the brake adjuster to keep my pedal decent.
Now if you are sitting at a stoplight with your foot on the brake pedal stopped. With you feeling the pedal creeping to the floor slowly moving. Mostly that is caused by seeping o rings on your master cylinder plunger itself.
Old 07-12-2022, 03:57 PM #19
Obviously...
The drums are mechanically adjusted by using the parking brake. The shoes can 'over retract' and cause excessive pedal travel if not adjusted correctly. It also feels very odd when it does this.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-12-2022, 04:52 PM #20
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Obviously...
Had the same issue. Pedal travel to the floor. Brakes only grabbed in last 1/4 of travel and couldn’t get it to ABS. One drum was like 1mm off the shoes. Other one wouldn’t even come off. Adjusted both about 4-5 clicks and totally fixed the issue.
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 07-12-2022, 07:08 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup it doesn't take much of adjustment either. I really expect half of the spongy brakes are simply not adjusted rear drum brakes.
Old 07-13-2022, 02:51 PM #22
schmauster schmauster is offline
schmauster is on a distinguished road
The rod moves and you can hear the master cylinder pedal travel but nothing happens till the bottom 1/4 like everyone else said. Its enough to scare everyone who drives the car.
I grabbed an ABS actuator at the yard.
I suspect it is probably just air in the ABS module but ill see what happens.
I have all the tools and time to crack the old ABS module open, harass me till that happens.
schmauster is offline   Reply With QuoteReply With Quote
Old 07-13-2022, 05:52 PM #23
If you didn't follow the bleeding procedures I posted to a T - especially the master bleeding portion - it is a bleeding issue, not an ABS issue. The extra little bit on the side of master works with the rear drum brakes for better brake feel, but if it is not bled correctly it RUINS brake function/feel, just like you described.
Old 07-13-2022, 10:42 PM #24
I bench bled (bottle with a tube in it) the junkyard ABS module with the gf's help and installed it. Bled the brakes and it is absolutely fixed, there is almost no travel in the pedal before they engage.
Most likely air. I took it out and engaged the ABS a few times and its still perfect.
If i were to do it again i'd remove all the lines on my factory ABS module and bench bleed it. When i tapped on the little circles on the sides of the module i got more bubbles out. They seemed to displace fluid when tapped on which let me get all the bubbles out.
Old 07-14-2022, 04:12 AM #25
Long brake pedal travel
It can if it is way loose, but he tightened it too much. That won't be the issue.
Here's the factory procedure for the '96-'00 4Runners:
Pay special attention to the master cylinder bleeding procedure and wheel order. If that doesn't work, go activate the ABS system and bleed again. It may take a couple ABS cycles and bleeds to get all the air out.
When I replaced the cracked front hoses on my 97 Project I had killer pedal feel until I went and activated the ABS in the rain. Pedal went soft instantly. It took me three times to not have a difference in pedal feel after brake activation.
Edit: I’ll also add that my 94 Dodge Ram Service Manual specifically says not to pump the brakes before opening the bleeder. Because it takes one big air bubble and turns it into millions of tiny air bubbles.
It says to open bleeder-depress pedal-tighten bleeder-release pedal. That’s how I’ve been doing it since I read that in 1996 until I got my pressure bleeder.
Old 07-14-2022, 10:15 AM #26
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That's how I've always bled brakes. There is no advantage to pumping the brakes during the bleeding process. It only creates more bubbles and potentially migrates them up toward the master.
Old 01-20-2023, 01:08 PM #27
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
So, to resurrect and add to this post...
('96 SR5)
I've been dealing with this myself. It seemed to be getting worse so "assumed" the MC was leaking down. After 370k miles, I could understand. I have done the TBU, using Powerstop calipers/pads so it made sense to me that there may be a little more travel to start but it was getting softer.
Changed out the MC (no, not OEM, the Horror!). Bench bled, did a pressure bleed with a Motive system. Didn't seem to help. Checked rear brakes and made sure they were adjusted correctly. Re-bled with the Motive with engine running. Steady clean stream of fluid, no bubbles. A little better, but not great. Drove it that way for ~200 miles.
Decided to go through and re-bleed it again. Got the Motive set up, key on (ABS pump active), then went through and tapped on the MC and ABS to loosen any bubbles. Went to the RR and lo and behold, got a lot of bubbles. Actually surprised at the air pockets that came out, took a while to get it back to a clean stream of fluid.
Moral of the story, if you think you have it bled, it probably isn't.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
braided , cylinders , long , upgraded , wheel
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Having the long brake pedal travel/low brake pedal mystery problem Dragon_EX 3rd gen T4Rs 16 05-19-2021 10:58 AM
Long Brake Pedal Travel vs Soft Brakes stever1000 3rd gen T4Rs 17 04-26-2018 01:27 PM
Long Brake Pedal Travel flyinbrick 3rd gen T4Rs 11 10-10-2017 06:12 PM
Long brake pedal travel Jeremy03Sport Maintenance/Detailing 16 06-15-2006 09:37 AM
