Old 07-09-2022, 07:58 PM #1
The bear The bear is offline
The bear is on a distinguished road
3 gen UCA bolt length
Hey folks do you know the length of UCA bolt for 98 4runner?
I have a BCC UCAs which are Total Chaos replica if I understand it correctly. and driver-side bolt is bent. According to the manufacturer stock bolt should be used, however, the one I got from the Toyota dealer is roughly a nut length too short so I wonder if they gave me the wrong bolt?
I've called a few dealers but they don't know the dimensions and don't have them in stock to measure.
The bear is offline   Reply With QuoteReply With Quote
Old 07-09-2022, 08:53 PM #2
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Total length including the bolt head on my 97 with stock UCAs is 12 3/4". Should be the same for 98. The threads stick out 1/2" past the nut.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 07-24-2022, 08:33 PM #3
Thank you for the measurements.
The one I got from Toyota is exactly the same. But the ones I have now seems to be longer (hard to measure on without removing the bolt) and threads stick out by slightly over an inch. Interesting
Old 07-31-2022, 02:26 PM #4
orbot orbot is offline
orbot is on a distinguished road
Want longer bolts get a 4th gen or 2nd gen taco bolts they are like 2” longer
orbot is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 10:43 PM #5
good info, thank you! do you know the length by any chance?
I've pulled one bolt today and it's 3 cm longer than the one from the dealer.
322 mm vs 352 mm
it's still very confusing because total chaos insists that the stock bolt should be used.
3 gen UCA bolt length-uca-bolt-2-jpg
Old 08-01-2022, 11:56 AM #6
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
What is the width of your upper control arm? I can measure my TC upper arms when I get home.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
bolt , length , nut , stock , uca
Strut Mount Bolt Length jfeltT4R 3rd gen T4Rs 4 01-06-2021 02:09 PM
Front Caliper Bolt Length gookies 4th Gen T4Rs 4 10-11-2020 10:05 PM
Nut & bolt rather than rivnut install on full length Front Runner Rack? MtnMan219 5th gen T4Rs 22 06-10-2020 01:25 PM
Wheel bolt length greater than 27mm? benjamin247 3rd gen T4Rs 1 02-10-2020 12:25 PM
Body Lift Block ID/Bolt length- Steering Shaft bolt length 02_SE_Runner 3rd gen T4Rs 6 03-15-2013 09:57 AM
