Old 07-16-2022, 03:46 PM #1
RidingDirty RidingDirty is offline
RidingDirty is on a distinguished road
FIPG for front axle tube at differential?
I'm certain that I'm overthinking this, but here we go. I'm doing a manual hub swap and ADD delete. I have a non-ADD axle tube that I'm going to install, but there is a little confusion on the correct FIPG that I am supposed to use. My FSM says part "08826-00090, Threebond 1281 or equivalent" and usually that would be the end of it. The problem is that this part 08826-00090 corresponds to FIPG (orange) for the transmission and there is another part number FIPG (black) which is for oil. Since this is for my front differential, than wouldn't I need the black FIPG? Also to add to the confusion there is a Threebond 1281 (gear oil) and 1281B (ATF). So can anyone give me some clarification on the correct FIPG?
Toyota Adhesive & Sealant Cross Reference Chart - YotaTech Forums
Silicone RTV Sealant | ThreeBond
RidingDirty is offline   Reply With QuoteReply With Quote
Old 07-16-2022, 05:05 PM #2
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
I would use permatex 81182. It’s FIPG meant for gear oil, and what I’ve always used for gear oil applications. I’m interested to see what Toyota/three bond people recommend for gear oil applications.
Bad Luck is online now   Reply With QuoteReply With Quote
Old 07-16-2022, 05:33 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I believe three bond 1281 is reddish brown. Description: [Silicone FIPG, Gear oil resistant, heat resistant]
It's also the same color as 1281B [Used in Silicone FIPG, AT fluid resistant ]
I would use 1281 for the gear oil sealing and 1281B for the Transmission pans etc.
This is just my thoughts on it. :-)
I just found it interesting as its the same color as the factory FIPG. :-)
Old 07-16-2022, 07:32 PM #4
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I used Permatex Black RTV on my actuator, and it seems to be holding almost a year and a half dozen wheeling trips later.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 07-16-2022, 07:34 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am sure it will. As it's probably an equivalent. Lots of things should work well for many different mfgs.
Old 07-16-2022, 11:36 PM #6
4Reak Show's Avatar
4Reak Show's Avatar
I don’t know the part number but the orange/red Toyota FIPG is a great product. Expensive but it’s the right stuff for gear oils from what I understand. Rule of thumb: black FIPG on engine oil/coolant. Red/orange FIPG on transmissions and diffs.
That has never steered me wrong.
Old 08-09-2022, 09:54 AM #7
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I can't seem to find Threebond 1281 when I want it lol
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-09-2022, 12:00 PM #8
Real Name: Patrick
Real Name: Patrick
Aisin slapped their brand name on some: AISIN AB1281B Form-In-Place-Gasket (FIPG) For Japanese Imports | eBay
Old 08-09-2022, 12:07 PM #9
Originally Posted by Bad Luck View Post
I did see that, crazy shipping cost lol
Permatex Grey seems just as capable and readily available
Old 08-09-2022, 04:10 PM #10
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The Red/Orange is the right stuff for transmissions and differentials.
#00295-01281
08826-00090 , correct , fipg , part , threebond
What tube is this: rear differential thobry 3rd gen T4Rs 8 10-04-2020 03:00 PM
FS: 4th Gen Rear axle housing and front differential $400 Nickname For Sale: T4R Items 0 12-27-2019 07:21 PM
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
Front Differential Axle Seal Replacment mtbtim 3rd gen T4Rs 2 02-07-2017 06:04 PM
Right front axle play at the differential Atomic_Dog Classic T4Rs 6 02-14-2012 04:10 PM
