Old 11-02-2023, 09:43 PM #76
chapolito's Avatar
chapolito chapolito is offline
chapolito will become famous soon enough chapolito will become famous soon enough
chapolito's Avatar
Another amazing Baja trip—6 weeks and 3700 miles.
It was a mad dash to prep, but we got the roof rack completed. Original plan was to do a two layer perimeter just like Gobi's, but we were running out of time so stuck with a single layer.
Lots of notching, welding and grinding. Rigged up a notching jig for the drill press and kept the compressor blowing air the entire time to keep things cool:
Added two surfboard racks with capped ends:
Added 6 feet to bolt down into the factory rails:
And two tabs to bolt feet into on the front:
Added 3 of these tabs for the awning to bolt on to.
Finally paint!
In between all of this, we added a second 100Ah battery, second 100w solar panel, and an inverter. All so that we could run Starlink while in video calls all day from the beach:
Awning broke the second time we used it when the wind gusted unexpectedly. 20 zip ties and 5ft of duct tape later and it was working again.
Only car issue was that one of the top nuts on the drivers rear shock worked itself off on a washboard road. Had to drive 400 miles without it before I had a chance to get a replacement nut and washer.
While I was under there I finally discovered what was making so much noise—the front end links weren't torqued down enough to the LCAs. After tightening the suspension is completely quiet and finally feels dialed.
We didn't really score great waves, but the real highlight was the epic freediving and spearfishing—we ate fish almost every day and saw beautiful sea life like spotted eagle rays.
And explored a ton of the gulf we hadn't seen before.
It was an epic trip.
chapolito is offline   Reply With QuoteReply With Quote
Old 11-03-2023, 06:27 AM #77
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
That's awesome. Looks like an epic trip.
How much do you think that roof rack weighs?
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 11-03-2023, 11:43 AM #78
chapolito's Avatar
chapolito's Avatar
Just the rack is probably 60-75lbs, but with the solar panels and awning over 100lbs.
Old 11-04-2023, 05:30 PM #79
chapolito's Avatar
chapolito's Avatar
I spoke too soon on broken parts. Just got under there while washing and found both end links in the front sheared off. I know they were intact a few weeks ago when I tightened them, but they sure look rusty already!
Old 04-27-2024, 10:59 AM #80
chapolito's Avatar
chapolito's Avatar
As great as the 4Runner is, our extended Baja trip highlighted the lack of space to work comfortably. This made work + travel really difficult, but we wanted to do more of it. So, we upgraded to a flatbed Four Wheel Camper on a second gen Tacoma. Lot's of projects already completed, but that's for another forum.
This 4Runner may never see Baja again, but she's still got a lot to give as my daily. I might need to drop baja & camper from the thread title. Anyways...picked up some clean limited wheels:
Still need to finish painting some silver center caps, but in the meantime I added sound deadener to passenger and driver doors:
My taillights were cracked, faded, and full of condensation. Replaced with some late model ones and swapped in LEDs. Took a little splicing to go from 7440 to 921 reverse lights.
My main goal was brighter reverse lights, but thought LED brake lights would be a slight safety improvement (they turn on slightly faster + brighter) But I feel the tail lights are too bright when not braking that it makes the brake lights not feel as bright in comparison. I probably will swap out for a different brand or back to halogen bulbs. They also have a pinkish hue since they are red LEDs, not a orangish hue most cars have.
And finally, I thought my clutch or transmission was going out—was getting super hard to shift into gear & 5th was regularly grinding. But after reading the FSM, was able to adjust the clutch pedal and everything is back to normal. replaced the tiny little rubber pads down there, one was in pieces.
doc , rear , reference , replaced , roof
5th gen 4Runner micro camper build Blackwatch 5th gen T4Rs 2 12-31-2021 01:49 PM
WTB 4th gen (or other?) camper build rhoyneriver Want to Buy/Trade 0 08-17-2021 01:34 PM
Sir William's Expedition Camper Build SirWilliamGoes 5th gen T4Rs 1 08-21-2018 04:17 PM
A real Surf! Turbo Diesel with manual KainDrag Classic T4Rs 11 05-20-2016 07:56 PM
TOYOTA HILUX SURF 1997, diesel: oners' manual sewe Maintenance/Detailing 1 01-19-2005 07:58 PM
