Originally Posted by Boognish_Forever
I tested to see how high the temp would go idling with the ac on in hot weather a couple weeks ago and it stayed around 205 as well. I was just gonna go with an oem clutch and buy some new bolts being mine a little rusty.
Aisin should work fine. Although the oem lasted 400k+ miles. The fan is held on to the fan bracket with studs and 12mm bolts. Wire brush the studs and and a little antisieze and you should be good. The nuts are not so tight, think the torque value is 65 inch lbs or so. I just hand tightened mine.
Note: There is a member here who sprayed the spring coil that engages the fan clutch located at the front of the fan with wd40 and had the fan operating well again.
edit: the fan itself is attached to the clutch with 10mm nuts.
