Old 07-29-2022, 07:47 PM #1
vonhughes vonhughes is offline
vonhughes is on a distinguished road
Question What does the CCV hose do?
Getting ready to swap out the PCV valve and grommet on my 2002 SR5, and I think I may have a small crack in what the diagrams say is a CCV hose.
What in the heck is a CCV and why does it have a hose?
The hose is coming from the air box, across the front, just above the spark plug wires and all the way to the other side of the engine bay.
Can I tape it or should I replace it? Other than being long, it looks like it would take < 5 minutes if one had a new hose on hand.
Thanks for helping me learn!
edit: here is the hose diagram. Ignore the yellow highlight and see CCV hose below it. The highlighted hose is Hose #3...
vonhughes is offline   Reply With QuoteReply With Quote
Old 07-29-2022, 08:40 PM #2
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
214RUNNER's Avatar
Crankcase vent hose vents the crank case fumes back in the motor
214RUNNER is offline   Reply With QuoteReply With Quote
Old 07-29-2022, 09:00 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If you look at the op’s attached picture you will see the pcv hose (positive crankcase ventilation hose) is separate from the ccv hose.
Old 07-29-2022, 09:07 PM #4
Real Name: Patrick
Real Name: Patrick
I have a 2000 so my engine bay looks a little different. That hose for me goes from the air box to the charcoal canister. Your charcoal canister is located under the vehicle by the fuel tank for you. Does it connect to a pipe attached to the firewall that goes under the vehicle?
Old 07-29-2022, 09:16 PM #5
It's too dark out now, I can't tell.
I think it went to a "T" and then went under the vehicle.
Based on an earlier reply, I did find a "Toyota 23830-62010, Hose Assy, Fuel Vapor Feed" that per the diagram at TOYOTA 4RUNNERVZN185L-GKPGKA - TOOL-ENGINE-FUEL - VACUUM PIPING | Japan Parts EU seems to be it.
If this is it, how many damn hoses return air to this engine?
PCV, CCV, "Hose #3" and what else?!?!?!
Old 07-29-2022, 09:45 PM #6
Oregon Runner Oregon Runner is offline
Real Name: Dylan
Oregon Runner is on a distinguished road
Real Name: Dylan
It vents your gas tank fumes back into the engine. The charcoal canister scrubs the fumes when the pressure sensor on the tank deems it necessary to vent it back into the intake. Technically you could vent it to atmosphere with no ill effects other than an engine bay that smells like you just cracked a gas can on a 95* day that's been sitting in the sun for an hour...best just to replace the line...
Some of my 3Rd Gen 3D printing projects here...hit me up for custom designs
https://www.thingiverse.com/groups/3...4runner/things
Photo Dump of my 4Runner / Toyota projects, TONS of fab and CAD pics...
https://photos.app.goo.gl/hCSpkZ6nLwMPCCXH6
Oregon Runner is offline   Reply With QuoteReply With Quote
Old 07-29-2022, 09:53 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The 2001 and 2002 have a pile more emissions lines on them. As the charcoal canister is back next to the spare tire. 2 lines come up from that box to the engine bay.
Best to replace it as I hate to see someone having a smoke with your hood open and go up in flames and ruin your rig.
Old 07-30-2022, 12:46 PM #8
I'm with you, brillo!
For a couple of dollars a foot at the local parts store, I'll buy hose all day when in doubt. What kills me is taking the darn thing off and walking into the parts story with a dirty old hose like a ding-a-ling.
Is this kind of hose sold/marketed by ID or OD? I put some calipers on the nipple of the air box where it attaches and got just a couple of thou over .400"...so I'm assuming the ID is gonna be a little under that...maybe 3/8"?
Tried to measure OD on the hose and got .530" or so, but I'm not sure I had it squared up perfectly. Plus I just have Kobalt calipers, not Mitutoyo or some high end kind!
Old 07-30-2022, 10:31 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
All Toyota hoses are in metric. Worst case mostly you can get the hose off of Toyota if need be.
bay , ccv , engine , hose , side
This hose is developing a crack but I don't know what the hose does or is called... vonhughes 3rd gen T4Rs 9 07-04-2022 11:08 PM
V8 Radiator Hose - Silicone hose replacement? t-rex grrr 4th Gen T4Rs 3 10-16-2015 12:14 AM
Help Identify Water Inlet Hose / Water By-Pass Hose No. 2 fysho31 4th Gen T4Rs 0 11-10-2014 12:43 AM
Problem - Missing Hose and Loose Hose Splashsky Classic T4Rs 2 04-07-2014 06:06 PM
Which water pump? Hose or no hose? Daveed Classic T4Rs 3 10-16-2006 01:15 PM
