Old 09-29-2023, 05:06 PM #1
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Compression Check with Intake Manifold off
I removed the intake manifold on my 2000 5VZ-FE 3.4
I want to check the compression before putting things back together.
Can I just disable the fuel pump and crank it with a key?
thanks
btw thanks to Tim the Toolman, his video helped a lot.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 09-29-2023, 07:44 PM #2
thanks
That should be ok. Pull the ECU fuse also.
You don’t have to block open the throttle plate if it’s not there. Compression Check with Intake Manifold off
Old 09-29-2023, 07:48 PM #3
Thanks for the confirmation and info on the ECU fuse.
It is handy having the throttle body off!
Old 09-29-2023, 10:11 PM #4
One of the issues I have with a compression check is watching the wrong” most popular” YouTube video that mention not holding the throttle wide open while doing the test.
check , compression , intake , manifold , pump
Really gummed up intake, under the intake manifold. Advice? ShooterMcGavin 3rd gen T4Rs 109 11-24-2020 02:34 PM
Compression Test: Bad intake valve? zazzomicron 3rd gen T4Rs 12 07-19-2017 01:51 PM
FS: 3rd Gen Upper Intake Manifold Plenum & Lower Intake Runners - Cen TX; Will Ship SURF RUNNER For Sale: T4R Items 19 01-10-2016 12:22 AM
After compression check CEL on with code 22 graeaglecrawler Classic T4Rs 2 10-22-2011 09:29 PM
Cant do a compression check dayno Classic T4Rs 6 09-19-2011 01:28 AM
