Originally Posted by T4Rscott
So as some of you know I’ve been dealing with an annoying AC issue.
After a lot of diagnostics I believe my ECM may been the culprit.
I obtained a used ECM from another 99 4Runner and it has a chipped key with it. Is there anything I need to do to get it to work in my SR5?
Thanks
If it has an immobilizer (chipped keys) then your SR5 doesn’t have the components and wiring/connectors necessary to read the chipped key to allow the ecm to start the engine.
It would be a lot of work to add the necessary components in order to make your new ecm work with your current vehicle. I’d recommend finding another ecm that doesn’t have an immobilizer. If it helps with your search, for your year only Limited trims have an immobilizer in the ecm.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
